VERY Quick Question re: Resetting CEL
Old Nov 28, 2009 | 08:34 AM
lillexrx's Avatar
lillexrx
Default VERY Quick Question re: Resetting CEL
Please help...
I need to reset my CEL and don't know whether to pull the ECU 7.5A or the EFI 20A... ??
Thanks!
Old Nov 28, 2009 | 10:03 AM
salimshah's Avatar
salimshah
25 Year Member
Removing the battery terminal for 20 min or so should do it too.
First I would move my seat etc to favorite settings and then disconnect battery. [search may give you the fuse number]. Then when I put the terminal [or fuse] back I set store location without moving the seat.
Salim
Old Nov 28, 2009 | 11:59 AM
mikey00's Avatar
mikey00
ECU fuse won't reset the CEL. EFI fuse will and it doesn't affect the seat positions in memory.
Old Nov 28, 2009 | 12:49 PM
lillexrx's Avatar
lillexrx
Thanks for the replies. You're right, the ECU didn't do anything... Next time I'll pull the EFI. Ended up going to Autozone.
Old Dec 1, 2009 | 06:29 AM
ByTor's Avatar
ByTor
But, how long will the CEL stay off with the EFI fuse pull ? Minutes, Hours, Days ???
Battery disconnect lasts about 1 hour. If I can get 1 day out of the EFI fuse pull, I guess that is better ??
Old Dec 1, 2009 | 07:38 AM
mikey00's Avatar
mikey00
How long it stays off is not affected by the method you use. The ECU is reset and will stay off until another problem is detected. Problem is that if you don't fix the condition causing the CEL it is detected again after a pre-determined number of cycles.
Old Dec 1, 2009 | 10:27 AM
ByTor's Avatar
ByTor
That was what I was getting at. Only a temporary fix. I find black electrical tape to be a better temporary fix.
Old Dec 1, 2009 | 12:58 PM
mikey00's Avatar
mikey00
It was never meant to be a fix either permanent or temporary. It is just a method to reset the light after you have done the required repair. Or I suppose you could use it to reset the light and wait for it to come on again just to verify that you do have a problem.
Old Dec 2, 2009 | 04:00 AM
ByTor's Avatar
ByTor
I understand what you mean. I just did not want the OP to think it was a fix. Another question for you mikey00, if there is a predetermined number of cycles for the light to come on again after being reset, is there also a pre determined number of cycles for the light to go off without getting the problem fixed ?
Old Dec 4, 2009 | 04:47 AM
ByTor's Avatar
ByTor
Well, apparently no "pre determined" number of cycles for the lights to come back on.
The latest for me was 3 days, approx. 8 hours of drive time between when they went off by themselves, and when they cam back on by themselves.
I'll let you know when they go out again, even if it is of no interest. The vehicle performs and drives no different when lights are on or when they are off. I should
have it scanned so I know what the codes are, but in no hurry as at this point it makes no difference on or off.
Old Dec 5, 2009 | 08:44 AM
ByTor's Avatar
ByTor
Lights are off today(CEL and VSC) after 2 hours of drive time and six ignition on,ignition off cycles. They were on when I started it up this morning, took a 10 minute ride to the store, shut it off, shopped, re-started and lights were off.
Old Dec 5, 2009 | 06:08 PM
Lexmex's Avatar
Lexmex
Yes, those wonderful CEL lights can shut off by themselves if the condition is no longer detected. You will still see them if you hook up a scanner (they're stored in there until you clear them), but the CEL light won't come on any more. In fact, I remember a few times I'd be going down the Periferico (that's one of the big expressways in Mexico City), the CEL came on, I went to reach for my OBD2 scanner and a few seconds later, the CEL went off. Can even happen to you in the case you just mentioned where you start up the vehicle again and no lights.
JKBHEAT
Jan 24, 2017 11:54 AM
Performance
29
Sep 10, 2016 01:18 PM
wayman28
Sep 23, 2014 07:48 PM
Lextasy89
Jan 31, 2008 10:15 AM
mrpogi
Jul 27, 2002 06:27 PM
