Driver's Window Sticks
This is an intermetting problem that has gotten worse. The window will go down without any problem, but getting it up can be next to impossible.
I've pulled out the master switch, taken it apart and cleaned it. When I pull the switch to raise the window, I can hear the relay in the siwtch "pop." It just does nothing to the window.
I've seen posts that say its the regulator or the switch. Is there anyway to narrow it down to which of the two is bad?
Thanks.
Thanks.
Thanks.
Thanks.
