battery issues
Old Jan 19, 2009 | 08:56 AM
magz11's Avatar
magz11
Default battery issues
Hello, i am a new member and i am having some issues with my 1999 rx300. The open door light on the dash is indicating a door is open but no there is not a door open.This is causing my battery to die, i think. Some pointers on how to fix this problem would be awesome.
Old Jan 19, 2009 | 09:00 AM
salimshah's Avatar
salimshah
25 Year Member
Check all five doors. Have another person close the doors & trunk and watch the display to see if the light goes off momentarily (will mean door/hatch needs adjustment).
The door close sensor is built in the locking mechanism.
Good luck hunting.
Salim
Old Jan 19, 2009 | 12:52 PM
magz11's Avatar
magz11
any other suggestions? been screwing with it all day still can't figure it out.
Old Jan 19, 2009 | 01:25 PM
salimshah's Avatar
salimshah
25 Year Member
You have to then tap into connectors and with a ckt diagram figure out which door is giving the problem.
Other than the instrument panel display, what is happening to the courtesy light if set on door. I am assuming it does the same, which mean the door switch is the culprit. If the light functions properly then it could be the ecu [you may like to reset the ecu by disconnecting the battery for 30 min]
Salim
MrMark
Jul 2, 2015 03:37 PM
Golden95SC
Oct 21, 2012 08:07 AM
igorxx
Feb 23, 2012 07:26 PM
shagadelic
Dec 26, 2007 07:15 PM
akazemi
Jan 25, 2005 06:16 AM
