'99 rx 300 sun visors
Old 12-20-08, 09:02 AM
jag1
jag1's Avatar
Default '99 rx 300 sun visors
howdy-
wife's '99 RX has a loose left-side of course sun visor that deploys over bumps. handy if you're driving into the sun; not handy if it's dark out.
dealer wants 500 to replace, and i've tried several methods to tighten-up the roll-pin. no soap. any thoughts?
Old 12-20-08, 09:14 AM
bob2200
bob2200's Avatar
Welcome to ClubLexus!
This has happened to others too. If you use the search function, I think you will find that some have inserted a piece of sandpaper to give more friction, as I recall. That's one approach, I remember correctly.
Old 12-20-08, 09:45 AM
thomas1
thomas1's Avatar
Bob2200 I dont remeber reading that, could you find it, I couldnt....
Old 12-20-08, 10:29 AM
bob2200
bob2200's Avatar
Hmmm. I must have seen it here because this is just about the only forum I read. I'm still looking, but I did find this thread from 2005, entitled "How to tighten the sun visor?".
Old 12-20-08, 07:32 PM
salimshah
salimshah's Avatar
There is no adjustment. Replacement is the correct fix.
velcro is what I plan to do for mine.
Salim
Old 12-21-08, 07:37 AM
jag1
jag1's Avatar
tried the 'search' but didn't find anything? I know replacement is the proper fix, but $500.
I'll try the sand paper fix, have also considered velcro to hold it up but am not sure how it would adhere to the fabric in time.
I tried wedging some 8 penny coated nails into the visor at the hinge point to no avail. thought about super glue, but chickened out. I'll try the samd paper and keep you posted. have to do something;wife is on it!
thanks for the discussion.
Old 12-21-08, 08:23 AM
salimshah
salimshah's Avatar
Jag. I have the same problem but on the passenger side, so the replacement cost is less as the home link is not there. I would not pay labor to fix it as it is can be done by any one who can handle a screwdriver *dealer charge of 1/2 hr labor $50+)
Try searching the term "visor". I am too lazy to do it for you and post it here, but the only fix seems to be is stuff things along the metal rod.
I have also contemplated a small magnet and a pin (magnet glued to the visor side). Also check on ebay.
Salim
Old 12-21-08, 11:46 AM
sktn77a
sktn77a's Avatar
$187.50 at http://www.lexuspartsworld.com
Replace it - nothing else works (with the possible exception of the Velcro). Pop off the plastic cover on the shaft mount on the headliner, unscrew the mount and pull out the visor, unplug it from the harness in the roof cavity. 5 minutes, tops!
Installation is the reverse.
Old 09-06-09, 03:13 PM
kosmo69
kosmo69's Avatar
keith, the price is $704? WTF!!! how can it go up so much?
http://www.lexuspartsworld.com/Scrip...?idproduct=262
Old 09-06-09, 05:33 PM
mikey00
mikey00's Avatar
You are looking at part # 74320-48021 which includes the garge door remote buttons. It used to be available as part # 74320-48011 without the garage door buttons. I don't see it online now. You may want to give them a call. Or give IronToad a call.
Old 12-20-10, 01:34 PM
JSlaughter
JSlaughter's Avatar
Default Visor
Is this the price for the visor or the whole car?
Old 01-04-11, 02:13 PM
C-Stone
C-Stone's Avatar
I am trying this:
I purchased some Hillman plastic Push Fasteners from Lowes. I cut Velcro in a circle and stuck it to the top of the fasteners. Then, I drilled a 5/32 hole in the visor where I could see it would come closest to the headliner. Then, pushed the fastener into the hole. I then stuck the remaining fastener (inverted) on the installed fastener and pushed the visor up to mark the hole for the headliner. Then, drilled the headliner 5/32 hole at the mark and pushed the fastener up into it.
Both fasteners work perfectly and are stuck securely in their holes. The high quality Velcro seems to hold. We'll see how it works over time. Will report back.
Pic of the plastic fasteners--part number on bag (Lowe's):
Velcro for plastics, drill bit:
Finished Visor:
Old 01-04-11, 06:08 PM
defo
defo's Avatar
Originally Posted by C-Stone
I am trying this:.............
Creativity = A
Execution = A
Functionality = A
Aesthetics = F
Probably would have given a 'D' for aesthetics, if you used a tan colored velcro.
Old 01-05-11, 02:56 AM
Australian
Australian's Avatar
http://www.mrmikes.com/fieroquestions.htm#visors
Checkout this page it is for the fiero but will help as similar setup.
Other idea is get rid of the visors and add some LCD screen visors
http://cgi.ebay.com/ebaymotors/PAIR-...ht_3358wt_1002
$135 a pair + delivery.
Old 01-05-11, 07:41 PM
sktn77a
sktn77a's Avatar
It's not clear that either of these would work for the RX300. I thought C-Stone's solution was pretty good, if the plugs don't pull out (or the headliner pulls down) over time.
Quick Reply: '99 rx 300 sun visors
