Where's the door switch?
Hey, I have a 99 RX300 and I am trying to figure out why the "door open" light in the dash doesn't always come on when I open the front doors. I don't see any visible door switches of any kind, are they some sort of magnet switch in the body and door?
The light usually comes on after about 30 seconds, but often it doesn't come on at all, occasionally it comes on right away like the back doors. For some reason this problem is only with the front two doors, the back doors always function properly. Maybe because they are used much less, but if it's a magnet sensor they shouldn't good bad, at least I would think. So if anyone can tell me where the door switch is located. Any info is greatly appreciated. Thanks, Garrett. |
Some one else can confirm, but Lexus uses the latch mechanism for door ajar or closed. If the problem is not in the wires or connectors, then it is in the mechanism and one has to replace the whole mechanical assembly.
Salim |
So you are reffering to the lock mechanism, the whole actuator/lock assembly? Well if thats the case I will find out soon because I just ordered one because the lock has been having issues locking/unlocking. So maybe I'll knock out two birds with one stone, I guess I'll find out. Thanks, Garrett.
No the actuator is a different piece. I am referring to the mechanism that grabs the hook on the door jamb.
Salim |
I don't understand what you mean by "grabs the hook on the door jamb"
Originally Posted by GCNTSi
(Post 2538296)
(Post 2538296)
I am basing this on GS. It is likely that RX has the same mechanism ... so I was hoping some one would confirm or refute. Salim |
Door switch
I just bought a 1999 RX300 for my daughter and this new/used car has the exact same problem. Both front doors don’t activate the front dome light or even recognized by the car dash that the front door is open. I’ve checked the fuse and the light bulb, both are fine. Please help! |
Originally Posted by ActionJack
(Post 10438430)
I just bought a 1999 RX300 for my daughter and this new/used car has the exact same problem. Both front doors don’t activate the front dome light or even recognized by the car dash that the front door is open. I’ve checked the fuse and the light bulb, both are fine. Please help! Salim |
Interior lighting
Is there any way to make the front dome lights turn on when you open the door? I know the rear ones do, but why not the front ones? |
Thanks Salim, I figured this out while playing around the back doors. |
Door ajar light doesn’t come one still
I changed the entire lock door assembly & actuator expecting the door ajar sensor would start working. Of the 100 times I opened the door, the ajar light came on only 3 times. Any idea what’s going on? I had to change out the actuator because the door lock wasn’t working but I really was hoping to get the ajar light to start working again. |
I bet you were expecting a simple plunger switch that directly turns on the light. No such luck.
The RX300 driver and passenger front doors have door ECU's that communicate to the body ECU. The body ECU then decides what to do. If you want more info, try googling for RX300 body electrical BE pdf RX300 diagnostics DI pdf |
Switch is only one piece of the puzzle. You have wires and connectors and modules. I would get ohm readings on the switch part-wires to determine what is wrong.
Salim |
| All times are GMT -7. The time now is 10:53 AM. |
