Engine pings under acceleration
Old Apr 9, 2006 | 06:21 PM
toyhauler's Avatar
toyhauler
Default Engine pings under acceleration
I don't know why this is happening. The Check Engine Light is not on. If I use hi octane fuel, the pinging stops. This vehicle should run okay on regular shouldn't it? This seems to be a recent problem, but I don't know why.
If anyone has any ideas, please let me know.
Thanks,
Ron
Old Apr 9, 2006 | 06:43 PM
salimshah's Avatar
salimshah
25 Year Member
With engine cold pop open the radiator and see if the coolant is full. Also check reservoir. Run heat for couple of minutes when engine is hot and recheck reservoir.
Next item would be the air filter.
Beyond these, you will have to make a trip to the dealer/trusted-mechanic.
Salim
Old Apr 9, 2006 | 08:05 PM
Fern's Avatar
Fern
Default Pinging.
Next time you get tank filled with Premium and get home.
Turn engine off and diconnect the EFI fuse in the engine compartment, I believe its fuse #13 (this will reset the ECU).
Leave fuse out for about 5 minutes.
When you re-install the fuse and then start up the car, you should not get the pinging again.
Had the same problem with my '99 despite using premium fuel.
Once I reset ECU, pinging went away and I have been using mid-grade ever since...
BTW mid grade gives me MUCH better/ smoooother trani shifts..
Try it out and let us know results.
Fern
Old Apr 9, 2006 | 09:59 PM
Lexmex's Avatar
Lexmex
Sharing south of the border experience,
Often times, my track runs won't be very pretty and the injectors will make a lot more noise than usual. Even though I run 92 Octane, the gas here is still loaded with more sulfur content than that found in the U.S. and I have no idea what other chemical impurities, but it never runs as well as back in the U.S., even when I am sea level places like Acapulco or Veracruz.
I then use a good quality fuel injector cleaner like Techron and/or Restore and the times get back up to snuff plus the injectors are quieter.
One good side effect of having higher sulfur is that the engine will run a little cooler.
Old Apr 16, 2006 | 12:35 PM
toyhauler's Avatar
toyhauler
Default pinging
Thanks everyone. I shall try everything you have suggested. I really appreciate your responses.
Ron
Old Apr 16, 2006 | 07:22 PM
salimshah's Avatar
salimshah
25 Year Member
Please do post, what worked and what did not.
Salim
Old Apr 16, 2006 | 07:41 PM
ravengotu's Avatar
ravengotu
Default mine does as well
But only when i put mid grade or lower octane.....you said no engine light...mine comes on as well with the pinging
Old Apr 16, 2006 | 08:34 PM
Lexmex's Avatar
Lexmex
That's probably a function of a rich/lean error, most likely a lean one.
Old Apr 17, 2006 | 12:19 PM
toy4two's Avatar
toy4two
get some BG 44k or get professional cleaning down.
Old Apr 17, 2006 | 08:31 PM
Lexmex's Avatar
Lexmex
What can happen using lower octane is that the burn is not crisp and there is some oxygen left over detected by the O2 sensors, causing the light. For as bad as the gas is down here, that happens when my injectors get clogged (just about every month I have to use Techron).
Old Apr 19, 2006 | 07:16 PM
Fern's Avatar
Fern
Default pinging
Hey toyhauler,
you mention the pinging is just a recent problem.
Whats the mileage of the vehicle and the condition of the emission control devise, ie: egr, o2 sensors, etc.
Has timing belt been changed recently?
The pinging may be due to a faulty knock sensor or possibly an EGR valve that is malfunctioning. Also, the timing belt being off a tooth or two could also cause this.
Either way pinging is not normal and should be looked after.
Old Apr 21, 2006 | 06:00 PM
HarrierAWD's Avatar
HarrierAWD
Thanks,
Ron
Since the pinging stops with high octane fuel, you may have carbon deposit somewhere in the combustion chamber. Most likely on top of the pistons. The deposit reduces the size of the chamber and cause the regular gasoline to "pre-detonate." Thus the pinging or knocking.
You can try adding a bottle of B-12 Chemtool to your gas tank, available at AutoZone. It worked for my GM car. Don't bother with Techron or STP stuff, they are just "feel good" products. Don't try oil additives, either. They don't get to the combustion chamber.
Next try would be GM's Tops engine cleaner (don't think Toyota makes anything like that.) Remove all spark plugs and pour the stuff in. Let it soak overnight. Put a towel on the engine and crank it to get as much gunk out as you can. Put the plugs back in and run the engine. Be warned that your tailpipe will smoke like a Marlboro Man for 10 minutes.
If it gets bad enough, you'll have to take it to the dealer. They'll have to take the engine apart to clean off the deposit.
sc4001992
Aug 21, 2024 04:30 PM
rgonza1
Mar 26, 2015 10:37 PM
JeffO
GX - 1st Gen (2003-2009)
Aug 6, 2014 04:30 PM
2JZwannabe
Apr 29, 2012 09:39 AM
johnnybmw1
Jan 27, 2009 05:08 PM
