RX 300 Rear Bumper
The plastic pad protecting the top of the rear bumper-cover on my wife's 2000 RX 300 keeps coming loose on the ends. [ protects from luggage, etc ] I've completely removed it , removed the old 2-sided tape, prepped it with 3M adhesive remover, re-applied new 1" 3M tape all around the outer edges and it STILL pops up on the ends. Very aggravating! The dealer wants $100.00 for a new one, plus installation, and they won't guarantee me the new one won't do the same thing. Anyone have a solution to this problem? ALSO.........Is Lexol leather cleaner/conditioner the way to go for the seats? Thanks.
After you used the adhesive remover, make sure you wash the area thoroughly with plenty of water.
Try double-sided Scotch tape instead. Those 3M automotive strips are a bit too thick so the edges will pop.
Agree with previous reply, wash the surface extra clean and remove ALL residue. Put a good warm soapy solution to the bumper top and protective step and then sponge down with plenty of water. I installed the step myself on my '99 RX and I cleaned the surface about three times and let it dry completely. Don't rush it and try to put it one before it completely dries.
As for double sided scotch tape, I don't think that's going to hold enough. I would go with the thin 3M tape instead. About the same thickness as the original adhesive tape.
I assume you have checked to make sure the protective step itself is not warped? $100 to install is sort of steep. You can get that yourself from Irontoad.com for around $68 and install it yourself, since you're doing that now.
As for the interior leather, I use a product called Macguire leather cleaner and it cleans fairly well. It doesn't leave the leather surface slippery after cleaning it like some other cleaners I've used before.
Good luck.
Good luck.
hawaiiboi
Nov 11, 2007 03:36 PM
