Weird Issue - 2002 RX 300 AWD
Old Aug 16, 2023 | 08:24 AM
rickz713's Avatar
rickz713
Default Weird Issue - 2002 RX 300 AWD
So, my comes on intermittently while driving long distances. I figured I'd just drain and fill and get some new tranny fluid in it. Did not have a chance to do that b4 my trip from Ohio to NY last week. A/T Oil Temp light was going on and off on on the way home. About two hours out, I see a white plume of smoke behind me. I got out at the nearest rest stop and saw, what I assumed was trans fluid splashed under the car. The white smoke was where it hit the exhaust and burned off in white smoke. Checked the oil and trans fluid levels... still good. Also checked the trans cooler.. no obstructions. Couldn't see nay obvious leak locations. So, with kids and dogs in the car, I decided to try and get home. Drive home was uneventful. No issues and A/T light never came back on. Took it to a local repair shop. He said that he can't find a leak or blown tranny coolant line but he said there is a small u shaped line above the transmission with what looks like a valve of some kind. He thinks it may be a relief valve of some kind and this was what caused the fluid splash under the car to relieve the heat/pressure in the transmission. I never heard of that but I figured I'd ask you guys about it as well as get your ideas on what the issue may be. Trans does shift a little slow between gears when cold now, but no other symptoms. Taking it to a tranny shop to have them take a look and do a drain and fill.
Old Aug 16, 2023 | 08:27 AM
salimshah's Avatar
salimshah
25 Year Member
You might have accidentally overfilled the transmission.
Please share how you checked the fill level/ Incidentally I have had difficult time reading the level on the dipstick even when I followed the procedure.
Salim
Old Aug 16, 2023 | 08:28 AM
rickz713's Avatar
rickz713
i have not added any fluid.
Old Aug 16, 2023 | 09:35 AM
maxSteel's Avatar
maxSteel
I've always associated white smoke with coolant and dark smoke with lubricants
Was the liquid under the car the color of transmission fluid or something else?
As for "Trans does shift a little slow between gears when cold now", how cold are we talking about?
If you mean "I get delayed upshifts for the first 3 or 4 minutes after I start the engine" that's working as designed
Old Aug 16, 2023 | 09:45 AM
rickz713's Avatar
rickz713
It was a dark oily fluid.. not coolant. All on driver's side. Was not oil. It was 1st 5 to 10 minutes.. never done that b4.
Old Aug 16, 2023 | 01:06 PM
salimshah's Avatar
salimshah
25 Year Member
Ripped CV boot will fling out the grease. Should be easy to trace but hard to see the rip visually as the bellows squeeze down on the rip as you lift the wheel.
Salim
Old Aug 24, 2023 | 04:17 AM
Australian's Avatar
Australian
Just draining fluid and refill isn't a service without the filter changed as it works on gravity and holds all the flow if blocked flow is the issue. You could add a cooler but it as long as have good flow of fluid all is good.
rickz713
Aug 3, 2023 11:34 AM
lespaul64
Jun 11, 2016 12:06 PM
Supremeg56
Florida Lexus Club
Apr 12, 2014 05:35 PM
FlyRyde
Mar 8, 2011 07:57 AM
Scott1258
Sep 8, 2007 06:55 AM
