2nd to 1st shift (jerk, push etc symptom)
When I was testing the LC500, I noticed that they have this issue fixed. I shifted down from 2->1 at low speed with no lurch / jerk. I wish they could update our ECU with just this fix. Also, that other issue with the slight power cut out at around 2800-3000 RPM is really annoying when you're playing a smooth symphony with the exhaust.
Waiting for the LC F, but im probably going to jump into a MP4-12C by then.
I have the same issue in my gsf also. I’ve been searching for a solution but no fix so far. It is the final downshift when coming to a stop and usually happens around the 20-18 mph range and a slight jerk. It feels like a match rev downshift but the engine and trans are off by a few 100 rpms. I’ve brought it to the dealership and did test drive with service manager and he acknowledges the slight jerk but basically said with out a check engine light and code, Lexus won’t warranty to tear apart the trans and there is no new software upgrade available. A solution I have notice is that if you put your car in sports + mode it doesn’t have this issue so mostly likely a ECM issue make sense. Hopefully a fix is found soon as Im with you that the anticipation of knowing the jerk is coming is very annoying and to the point of me almost trading in the car. And being a former ISF owner, that drivetrain/engine comb was super smooth. You could beat on that car and it wouldn’t skip a beat.
lobuxracer (01-11-19)
Tech Info Resource
Thats what I intially thought. The 2 - 1 downshift in auto mode.
Hey Guys,
As you might know, Lexus/Toyota has an ECM issue they never seemed to have fix for various makes/models which displays itself in a less than smooth downshift from 2nd to 1st gear. Some people notice it some people don't or some people just accept the car as is as one if it's characteristics. Many Lexus forum members have reached out to SIA Electronics in Illinois to have their ECM fixed and it has worked. I am currently in the process of doing this for my 2008 GS350 as it has this issue. I'm confident that the issue will be resolved and look forward to having this issue fixed.
On the other hand, I noticed my RCF does this as well as I recognize the symptoms from my GS. I contacted SIA and they do not have a fix for this yet for our model yet. I was wondering if anyone else has found any solution to this? Once I take my car out of storage, I'll be re-flashing the computer at the dealer to re-learn my driving styles etc as the car is new to me. But through research, I've read that this does not fix the issue. The car shifts beautifully and gracefully through all the other gears. My warranty is up in June of 2019 and I'll try to somehow get this fixed through the dealer but when I mentioned this to them they sorta acknowledged the issue and said that there isn't a fix.
Love the car but this is my only minor issue with it. I doubt passengers feel this subtle symptom but it personally bugs me.
Let me know your thoughts....
Did the RCF not exhibit these symptoms when you test drove it or did you not take it for a long drive? I’m assuming not since you are seemingly quite familiar with it through your GS.
Correct, I test drove it but it was on long country roads and I didn’t have the chance to drive it in a more stop and go scenario. On top of that, I really didn’t think this would still be a problem by now. After taking possession of it and once I hit the Toronto rush hour traffic chaos, that’s when I noticed it. Everything else is amazing on this car.
I have a 2017 RCF and have only had the car for about 3 months (bought used). I have noticed this same thing during normal auto mode coming down in speed around 20 mph (I am thinking 3 to 2 shift). It is not a strong jerky feeling, more like like the rear wheels are sort of dragging for an instant as the revs match. It is only at that shift.
I am glad to hear others mention so I know it is not my particular car. I did mention to my service manager when I got the oil changed and he didn't seem to know of anything about it (of course they didn't seem to know much of anything about the RCF - he had to look up how many quarts of oil it takes, etc.)
Love the car overall
Oh I see - I guess in normal mode, the ECU is probably shifting at different (lower?) points than what i'm performing manually.
Installed my ECU/ECM back in my GS350 yesterday and I noticed a significant difference in the transmission characteristics. It shifts smoother and quicker and it does not have that lurch anymore. It feels like a brand new sharp/crisp shifting tranny and I'm very happy of the overall fix. It fixed my over all upshifting too as every single gear change feels perfect. I'm really impressed with this fix/solution.
In regards to the RCF, it already shifts silky smooth, the only adverse symptom is that one downshift. I'll be following up with SIA Electronics to see if they eventually fix a RCF. If they do, I'll be doing this 100%.
Will update this thread if that occurs....
RC350s (02-03-19)
trevorpdx
06-12-17 10:56 AM
StLucchese
07-15-12 12:12 PM
