Battery post corrosion
Old Dec 28, 2018 | 05:30 AM
slper's Avatar
slper
Default Battery post corrosion
Any of you deal with this on the positive terminal on your RCF? I've cleaned it, vacuumed the dust while doing it and sprayed cleaner and protector and it's doing it again. I know you can buy the felt disc to put under a regular shaped posts and it helps. Is there anything out there for this odd shaped battery?
Old Dec 28, 2018 | 07:32 AM
LRCSALES's Avatar
LRCSALES
there is a spray Battery terminal protector spray. I wonder if its the area you live in. If it is excessive have the battery inspected by dealer.
Old Dec 28, 2018 | 09:07 AM
flowrider's Avatar
flowrider
Veteran: Air Force
I'm old school Vaseline has worked for me for years You smear it on very lightly on the top of the clean posts after the cables are attached. It lasts until the next time you fiddle with the battery. Also to clean off corrosion, you could get an inexpensive wire terminal brush:
https://www.amazon.com/s/?ie=UTF8&keywords=battery+terminal+brush&tag=googhydr-20&index=aps&hvadid=241911362773&hvpos=1t1&hvnetw=g&hvrand=14333215082607657351&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030014&hvtargid=aud-589036435099:kwd-3588687285&ref=pd_sl_80oorumbit_e https://www.amazon.com/s/?ie=UTF8&keywords=battery+terminal+brush&tag=googhydr-20&index=aps&hvadid=241911362773&hvpos=1t1&hvnetw=g&hvrand=14333215082607657351&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030014&hvtargid=aud-589036435099:kwd-3588687285&ref=pd_sl_80oorumbit_e
It fits over the terminal and you rotate it back and forth. I haven't needed to use mine in years.
Lou
Old Dec 28, 2018 | 09:33 AM
slper's Avatar
slper
I used a spray. I'll try Vaseline. Thanks
Old Jan 7, 2019 | 08:26 AM
Fysisist's Avatar
Fysisist
Coat it with dielectric grease. Vaseline is OK but typically melts and runs off when it heats up under the hood. You can get a little tube of dielectric grease for a few bucks, lasts for years.
Old Jan 7, 2019 | 02:55 PM
CAHWY128's Avatar
CAHWY128
I spray my posts with Corrosion X from time to time. No corrosion ever.
Old Jan 7, 2019 | 09:54 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
If your terminals are corroding, your battery is junk. The posts have seals to prevent hydrogen from corroding the posts. When the seals fail, the posts and terminals corrode. It is not normal for modern battery terminals to corrode.
Old Jan 7, 2019 | 10:08 PM
isfvss's Avatar
isfvss
Lowbux you beat me to it, and stop being so right all the time
Old Feb 11, 2020 | 11:44 AM
iH8RICERZ's Avatar
iH8RICERZ
Sorry to bring this thread back from the dead, but driving my F into work today, check engine came on and the car felt like it went into limp mode. Pulled up to a stop light and it damn near died at idle. Popped open the hood and noticed my battery terminals were all corroded. Went back down to the parking garage a little bit ago, disconnected the battery and cleaned off whatever I could and reconnected everything. Check engine light is gone, but we'll see what happens when I start driving.
I'll report later what battery i'm using and how long I've had it... doesn't seem like its been that long, but I could be wrong. Gonna try some vaseline when I get home and have it cleaned up better.
OldLs400
Apr 4, 2019 01:31 PM
Oliver Enterprises
Aug 3, 2018 04:42 PM
lexusk8
Maintenance
Sep 27, 2004 07:45 AM
