TOMS Suspension Bracing - Install w PICs
Not looking to Hijack or go Off Topic here:
Which Bar is the one seen going across the engine when ya lift up the hood?
Exactly what does that do for you, and who makes them?
Thanks!
Thanks!
Your #1 Lexus Vendor
Its the Toms Racing one.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Talk about a resurrection
Def assume there's been something created along these same lines for desired effect?
GS F tower bar is confirmed to fit RCF, also if you install the rear lower brace, ensure you have something to hold up the rear subframe(a jack to support on the diff), it will collapse on your face if not., and you will have a bad day. Also taking off the right wheel makes the job a 5 min job, ...so subframe support+right wheel removal= slide in bolt up tq=👌🏼
Thank you,., I just wanted to match everything in my RCF, I don’t even think the front tower bar does much, as the stock one looks more supportive than aftermarkets, prob just for looks. But I do have a Blitz tower bar, but everything else is TOM’s and it's irking me and prob pull the trigger and get the GSF bar to match
So, after experiencing a hefty increase in steering response and drivability in a full bolt-on G37s, I decided that I wanted to explore the notion of suspension bracing in the RCF. Many have told me the mod is not-needed due to the car being capable, as is. While I have Penske Coilovers by RR-Racing and the RR-Racing USRS, I wanted something to tie the car up since my experience with the G was so pleasant. Overall, I wanted these mod's for some time, yet I was told that fitment was an issue for USDM RCF's. I reached out to Lou from Mod In Japan, since he was receiving quite a bit of TOMS gear. Overall, he was a tremendous help and with multiple go-backs to TOMS USA and TOMS Japan, he made the transaction quite easy. Overall, I had my parts in under 10 days ( yes, thats coming from Japan directly!!! ). So, I tip my hat to Lou and team, for the prompt service and prompt delivery! My reason for so many "go-backs" was more fitment. Should the parts not fit, I didnt want to eat the cost. TOMS and MOJ assured me that all is well, and stood behind me as a customer. That's all I can really ask for......
Back to the parts.....
Below are the parts that were ordered......
All the parts and the part numbers
I couldnt order the top strut bar for the engine, as TOMS only has one for RHD cars or only JDM market vehicles. Also, I opted not to get the rear upper bar, due to not wanting to cut into my trunk liner. Overall, I will get the top mount strut bar once its released.
Overall, the parts are a simple bolt-on. TOMS instructions were in Japanese but thanks to google translate and a web conversation from NM to Tq......I was able to dial in the specs needed on the TQ wrench. all 4 pieces took about an hour overall to put on, as I did the install with my buddy who is a master Lexus certified tech.
First brace in the center - simple bolt on and tq to spec
Left side - rear
right side - rear
this piece is directly under the control arm in the rear - both left and right sides. the stock piece comes out, and this heavy duty piece is a replacement. Again, bolt off, bolt on and tq to sepc
This is the front brace - notice the headers and USRS. the subframe cover was removed and this was bolted in. Simple bolt back on of the removed parts, re TQ to spec and then replace the cover.
Rear brace installed - here shows both the TOMS replacement from before and the rear cross member brace. This one, you need to drop the back piece by the exhaust to get the the center bolts. slide the long bar in from one side, slide the other in......bolt on, TQ to spec.
Overall, the driving experience associated with these mods are quite noticeable. Immediately, the car felt more planted and more agile. I am now on 20" wheels and the car rides rough. I was able to get more "feel" back with this mod. On the way home, I took a turn at 70 mph, with my buddy the mechanic in his chase car ( a modded GSF ). He said the body on my car didn't move one bit, and he could visually see the car "track" around the turn with ease. I'm very happy! Now, its like the car is planted and gliding around turns vs the "plan" or "recognition" that rear has a little play in it and to feel for when the car responds. While these mods aren't cheap, I do feel more steering input, the car is more planted, and the feel is most certainly there. I cant wait to put my stocks back on and rip around the track. I have been a little busy with work, yet I know a track day is in my near future. I will keep everyone abreast of how the track day goes. For now, I would highly recommend this mod for those wanting a more planted, sharper, responsive and more alert car.
Left side - rear
right side - rear
Super old thread but since there's no update I figure it I'd post information since I just got done installing all of this.
The front black brace goes back on the car.
Did Tom's brace does not interfere at all with the installation All factory pieces are ret.
Hope that helps.
*Note that I do not have any of the bolts tightened on the black brace piece everything is loose at this point minus the Tom's bar.
-Nigel
07LXgs350 (01-28-24)
cspec
Suspension and Brakes
20
10-04-07 12:10 AM
