Wheels spacers for 2015 Lexus RCF stock wheels
Hi Club Lexus,
Any advice where we can get wheel spacers for our 2015 Lexus RCF stock wheels?
What is the recommendation, 15mm across the 4 wheels? 20mm? mix of 20mm front 15mm back?
I havent had luck in finding them to purchase.
Thnxs.
Thnxs.
Your #1 Lexus Vendor
I have a customer purchasing 15mm H&R spacers for the front and rear to match his Swift Springs. He said the 20mm would be good too, but doesn't want to risk anything, so 15 to be safer.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Spacers are a bandaid for wheels without a proper ET. A poor man's fix.
The more aggressive the spacer the more likely they are to fail. A 5mm spacer that uses the existing wheel lug studs will probably be perfectly safe so long as the studs don't have damaged threads (in which case they should be replaced anyway). Reducing the number of threads which the lug nuts thread onto reduces the force which the lug nut can handle before stripping the threads. So a 5mm spacer will reduce 5mm worth of the threads inside the lug nut. If some of those threads are already stripped then that compounds the matter.
A 15mm spacer on the stock wheel lug studs would be a bad idea (if it will even thread on...). In that case longer studs should be used, or a wheel hub adapter. But now you are at the mercy of aftermarket wheel studs. Perhaps they aren't as strong as the stock studs. How do you know? You don't. You have to take the word of the aftermarket manufacturer and the word of mouth from other customers. The wheel adapter itself could also fail. It's likely going to be made of weaker material than your stock hub.
Some people have used spacers and had no issues. Others have had horror stories. The bottom line; I wouldn't use spacers in place of a proper set of wheels. But I push my vehicles hard. They aren't show cars. It's dangerous enough pushing our cars to the limits. I'm not going to purposely introduce more possible failure points. To each one's own.
Yes 5x114.3
-Josh
-Josh
__________________
Orange County, CA
Orange County, CA
Also, if you use 20mm/15mm spacers on stock wheels, your car isn't going to handle as well as stock form unless you are on stock height or close to it. If you are lowered, your suspension geometry changes, and your camber will change. Then, when you add a significant size spacer like 15/20mm to that, your tire contact patch to the road is lessened. You may not be able to see a difference, but you will definitely feel it when driving.
nigel821 (04-21-24)
20mm in the front - 17mm in the rear
Most people thought the car came stock that way
It's a very subtle mod that adds a lot of visual appeal to the car. Don't be scared to use spacers, I've run the set up on the track many a times
If you get spacers, get hub centric spacers over those universal one-size-fits-all.
However, interesting enough do you know that when you order a Porsche in America they offer you the choice to add spacers (and they can get fairly aggressive)...I assume they are offering this for people that want to track their car and they must make some compensation for the suspension depending on which spacer you would go with???
And to that point I "do not" agree with people who think spacers are a bad thing...it is all in how you apply them. Oh and make sure after a few days driving remove the wheels and check the torque...LOL...which BTW you would need to do with a new set of wheels as well!
Tech Info Resource
Spacers are great for visual performance. They pretty much suck for mechanical performance unless you are using them to correct offset on aftermarket wheels.
The following 2 users liked this post by lobuxracer:
konichiwa3 (11-07-17),
nigel821 (05-25-23)
