RC F Aftermarket Wheels (Merged Threads)
#406
I experienced similar issues when inquiring 20" wheels with a step lip and/or lower offsets(RC F runs a stock high offset). After working with Dan over at BC Forged, I ended up pulling the trigger on a new set. He was extremely helpful, detailed to spec, and even provides some CAD sketches/renderings of the wheels. I'm certain he can assist with 19" wheel options. Another RC F member currently runs some 19" BC Forged wheels as well. I believe his IG is @nvmyrcf. Just a recommendation.
GunnyFitz (05-07-19)
#407
#408
This one?
Definitely a killer wheel, Dan was extremely friendly and helpful. No other vendors helped me on BCs.
https://www.clublexus.com/forums/rc-...e-caliper.html
#409
Some 19" eye candy! 19x8.5 +10 front 19x11.0 +38 rear with 245/35/19's and 305/30/19's. Need to find them a new home if any one is interest for cheap.
Thanks for the compliment!
Glad I could help out!
Will look him up. I think this thread has a Member w them and ironically another member likes the very same model I do!
#412
Not sure I agree with you on this statement Gunny... there are quite a few wheels in the 19x9 +30 to 19x10 +40 range that work just fine on the fronts, and 19x10 +40 work great as a square on all four setup too. I'd be happy to put a list together of some contenders for you if the help is desired...
#414
This is one of my favorite 19's...
https://www.clublexus.com/forums/rc-...ssr-gtx01.html
#416
This is incorrect information. Same thing applies to the 2IS and an IS-F and 4GS and a GS-F. All the rear fitment is exactly the same just the fronts are different due to the fenders being wider.
#417
Lexus Enthusiasts
The fronts are different however the rears are exact the same. Obviously pad heights may change due to the caliper differences between the two but that has nothing to do with the width of wheel the car can accept.
the RC OEM wheels are 19x8+45 while the RCF is 19x9+50 for the front, as for the rear, RC OEM is 19x9.5 +55 while the RCF is 19x10+40.
Its not just the brake clearance that changed between the RC and RCF, , the suspension is completely different from the RC and RC-F, allowing the F to fit wider wheels and less offset.
As for the aftermarket wheels option, RCF can take 1 inch wider wheels with 15-20mm less offset both front and rear. Not to mention the rear quarter panel on the RCF is wider
GunnyFitz (05-14-19)
#419
Incorrect?
