Front Lower Control Arm Bushing Bolt
Old Oct 27, 2024 | 03:13 AM
BLOCKSMITH's Avatar
BLOCKSMITH
2nd gear
Default Front Lower Control Arm Bushing Bolt
I've attached the media I've been able to find regarding this singular bolt that seems to be eluding me.
I've located this part number but I'm not 100% sure if it's it: 90119-16021 https://www.monotaro.com/p/2654/9942/
I'm pretty sure it is different from the ISF part number which is 90119-16013
I've beat my head against the wall with this for 5 or 6 hours at this point and have just been running in circles with it. Any help would be greatly apprecaited.
Old Oct 29, 2024 | 03:47 PM
stvincent's Avatar
stvincent
I hope what you looking for is listed in the following link.
https://www.lexuspartsnow.com/parts-...tml?pnc=43330M
Like you mentioned, hard to find that exact part number. It seems like it's a 22mm bolt with a washer.
Old Oct 29, 2024 | 07:34 PM
JT2MA71's Avatar
JT2MA71
It's part number 90119-16021. If you click 'view more images', its in the second diagram.
https://parts.belllexusnorthscottsda...102.html#51201
Old Oct 30, 2024 | 07:20 AM
LoSt180's Avatar
LoSt180
I came up with that same part number as well. On the SUSPENSION CROSSMEMBER & UNDER COVER page, specifically it's the bolt shown that goes into the rear of the front subframe. You have to follow the dotted line a bit because it shows that bolt going thru a chassis brace also.
Specs want that thing torqued to 143 ft/lbs, so it has a lot of forces applied to it.
rayray76
Dec 12, 2022 07:01 PM
yolopookie
Oct 18, 2019 09:34 AM
Savixor
IS F (2008-2014)
Mar 7, 2018 02:12 PM
newgsman
Suspension and Brakes
12
May 24, 2011 10:23 AM
CallmeQ
GS - 1st Gen (1993-1997)
Sep 6, 2009 12:29 AM
