Header install
Old Aug 30, 2021 | 12:38 PM
SlowAzIS's Avatar
SlowAzIS
Default Header install
So quick question while installing PPE headers on a 2015 AWD does the sub frame have to be dropped ?
Old Aug 30, 2021 | 12:41 PM
JNP1227's Avatar
JNP1227
Yes it does
Old Aug 30, 2021 | 12:44 PM
SlowAzIS's Avatar
SlowAzIS
Originally Posted by JNP1227
Yes it does
I was just emailed by RR racing and they said it doesn't ... so we're going to see how this goes 😂
Old Aug 30, 2021 | 05:31 PM
rcJten's Avatar
rcJten
Not sure how much different the RC and IS engine bay tollerances are, but I thought the same before installing into my RC350 AWD. RR said no need and sure enough I was able to get it done. Not saying it wasn't a pita, but I got them in.
Old Aug 30, 2021 | 05:34 PM
SlowAzIS's Avatar
SlowAzIS
what exactly did you have to do ?? For the driver side header also ?
Old Sep 1, 2021 | 10:44 AM
rcJten's Avatar
rcJten
For the drivers side, you will have to disconnect the front differential drive shaft from the transfer case. It is secured using allen head screws around the shaft. I used a rubber sheet from the hardware store, wrapped it around the drive shaft and then clamped a large set of vice grips to keep it from rotating. You will also need to disconnect the steering column from its knuckle and move it out of the way, it's held on by a single 14 or 16mm bolt clamped in a spline. Like I said, a pita but totally doable.
For the passenger side, remove the battery and intake manifold to get access to the header bolts.
ihateu3
Performance
Aug 2, 2024 09:12 PM
AlpineGS
RC - 1st Gen (2015-present)
Mar 2, 2024 08:48 AM
GhostDog88
Nov 22, 2022 10:12 PM
jgscott
Jun 2, 2021 12:47 PM
vraa
IS F (2008-2014)
14
Jan 31, 2018 10:12 PM
