IS 200T 2016 heating problem
Old Feb 28, 2021 | 03:40 AM
hassansarw's Avatar
hassansarw
Default IS 200T 2016 heating problem
Hello Member,
I am experiencing a really difficult problem any help or past experience in this regard will be highly appreciated as I have ran out of option.
Problem:
When the car starts first time in the morning, the engine coolant temperature guage rises. It goes up with the accelarator. It goes to full high. If accelerator is released it quickly comes down to normal range. This happens for about 15 mins after which the temperature stabalizes in its normal range and through out the day it doesn't go up.
Solutions done:
Replaced thermostat
-Replaced temperature sensor
- Replaced coolant
- checked all the fans
- Check for any issue on the system.
Please advise what could be the possible reason for this and what is the solution. thanks.
Old Mar 15, 2021 | 08:27 AM
DiverseIS's Avatar
DiverseIS
Originally Posted by hassansarw
Hello Member,
Problem:
Solutions done:
Replaced thermostat
- Replaced coolant
I've had that happen on my 2nd Gen 4runner with a bad air bubble in the line. I had to burp it by lifting the front of the truck in the air as high as I could go with my jack. I'm just guessing though.
Old Apr 10, 2021 | 04:45 PM
king1026's Avatar
king1026
Default water pump
same thing happened to me just had a bad water pump which i had to replace since it was out of warranty
Mar 19, 2023 04:35 PM
jshooter55
GS - 1st Gen (1993-1997)
Sep 23, 2012 05:47 PM
pearl95lex
Apr 5, 2012 08:14 AM
xsohaib
12
Dec 4, 2005 11:04 AM
