JB4 TMAP Sensor Doesn't Fit...
Old Jun 11, 2019 | 03:37 PM
blk200t's Avatar
blk200t
Default JB4 TMAP Sensor Doesn't Fit...
Has anyone had issues with the JB4 not fitting on their car? 3 out of the 4 plugs fit but one of the TMAP sensors won't click all the way in. It slides into the car's harness but won't get past the little plastic tab that allows it to click in under the harness buckle... Picture attached... does anyone recognize anything wrong/has anyone had this problem? I emailed Burger but wanted to hear from you guys too.
I drive a 2016 F sport...
Thanks.
Old Jun 12, 2019 | 06:15 AM
Flash5's Avatar
Flash5
Thanks.
I have the same issue. One doesn’t click all the way, I just use it like that and I haven’t had any issues since it’s pretty snug.
Old Jun 12, 2019 | 08:16 AM
Sheddy's Avatar
Sheddy
Remove the white part that is inside of the male plug (Lower connector on the picture)....
Old Jun 12, 2019 | 03:45 PM
blk200t's Avatar
blk200t
Yeah burger told me the same thing. I removed it and put it back in the OEM female plug and it still wouldn't click in. then I tried it without the white thing at all just to see what would happen and it still doesn't go all the way in...
burger is actually letting me send it back to them to check it out even though I live in California and didn't buy it directly from them. hopefully they send me one that fits or can fix the problem.
Old Sep 3, 2021 | 05:01 PM
Aymud's Avatar
Aymud
10th Gear
Hi I'm having the same problem on my is200t. The rainbow wires OEM wire wont connect. Do you mind telling me how to remove the white socket or what you did to resolve this?
Edit: I got it to go, working for me!
gu3rr13r
May 18, 2017 12:04 PM
mattbeeezy
Mar 2, 2013 10:42 PM
757jetip
SC400 / 300 Classifieds
Sep 19, 2011 07:39 PM
joewitafro
May 26, 2008 08:04 AM
