slight vibration at idle
Old Aug 7, 2003 | 02:50 PM
LEXISM's Avatar
LEXISM
Talking Vibrator
Well now that i have your attention it is more of a slight vibration,
I have 99 GS4 its almost time for my 90k mile service, I have slight vibration sometimes not all when I am sitting at a red light I ve noticed that If I press on the gas lightly while still holding the break it stops I guess beacause the car start to receive more gas will this be taken care of and stop after the 90k service or do I have to do something else anyone please thanks
Old Aug 12, 2003 | 05:59 PM
GSquicksilver's Avatar
GSquicksilver
welcome to the club of low rough idle GS4's! it's a common problem that lexus has no fix to it. do a search on our forum and you'll see what i mean. people have tried new throttle bodies, MAF sensors, TPS, you name it, it's been done.
Old Aug 13, 2003 | 04:02 PM
LEXISM's Avatar
LEXISM
thanks GSQS , I guess I dont feel that bad then since everybody has that problem i guess I'll try bananas method but thanks
Old Dec 3, 2003 | 12:20 AM
whitels's Avatar
whitels
Did you fix it? I'm having the same problem. Thanks.
Old Dec 31, 2003 | 09:09 AM
Fern's Avatar
Fern
Lightbulb rough idle
Just putting in my $.02
Was searching some of the forums and came across this.
Might not mean anything but "has anyone who is experiencing rough idle had their stock air filter replaced with a K&N filter prior to the rough idle?"
If so, I wonder if the hot wire on the MAF sensor has been coated with oil form the K&N filter and now is not communicating with the ecu properly.
If so, try removing the MAF sensor (located between filter and throttlebody and clean it out with carb cleaner)
Here is a pic of the MAF sensor location on my RX
Old Dec 31, 2003 | 09:48 AM
PHML's Avatar
PHML
Master Thread Closer!!
Try resetting the ECU (remove negative cable from battery for min. 1 hr.). Then re-install....start engine and rev it hard for 10 seconds or so.
Also, I would check all my fluids to see if its topped off. Check engine and transmission oil too.
Good luck.
Old Dec 31, 2003 | 11:19 AM
whitels's Avatar
whitels
Default Re: rough idle
This is actually a good thing to do every once in a while. My MAF was replaced by the dealer and my gas mileage jumped (use less gas). Perhaps, I could have just cleaned it.
mk4r34
Jul 31, 2013 04:28 AM
Salcedo90
GS - 1st Gen (1993-1997)
Apr 15, 2013 02:39 PM
lexus_sc400_n20
May 8, 2003 04:22 PM
GSquicksilver
Performance
12
Sep 6, 2002 10:45 PM
Synergy
Aug 22, 2002 03:24 AM
