Tanabe Exhaust Install help IS250
Old 11-03-18, 10:07 PM
TakaM
TakaM's Avatar
Default Tanabe Exhaust Install help IS250
I just installed the Tanabe Medallion exhaust on my 2007 IS250. In the process, I did replace the exhaust gasket with new Lexus OEM gasket. I torqued the spring bolts to 32ft/lbs as instructed by service manual. The spring is fully compressed and there's still some gap, to the point you can see the actual gasket. Is this correct? I couldn't seat the tanabe pipe to the OEM pipe any closer. Thought about using C-clamp or tightening the bolts further but I was afraid I will either damage the pipe or break the bolt. Please let me know if this is installed correctly. Thanks.
Old 11-04-18, 04:06 AM
bbaugher47
bbaugher47's Avatar
Is it leaking? The Tanabe should still be fairly quiet. So if the exhaust is pretty loud , you most likely have an issue. I reused the OEM gasket with no issues.
Old 11-04-18, 05:57 AM
TakaM
TakaM's Avatar
It’s quiet and did’t feel any leaks at idle. But with springs fully compressed, it probably doesn’t have the flexibility that OEM exhaust had. Wanted to double check to avoid any future trouble. Does your install look similar to this?
Old 11-04-18, 06:06 AM
bbaugher47
bbaugher47's Avatar
I have a different brand axleback , so it looks different but I would just monitor it and see how it goes. If it sounds like a straight pipe at some point , you have a problem. Lol. Also , it is normal for them to get a little louder as they break in.
Old 11-04-18, 07:35 AM
MikeFig82
MikeFig82's Avatar
It should be ok as mine is the same. The donut gasket doesn't sit flush in side the Tanabe flange. It's not designed like the oversized OEM axel back. Which the gasket sits recessed flushed inside.
Old 11-04-18, 02:46 PM
TakaM
TakaM's Avatar
Thanks Mike. That makes me feel better
Old 11-06-18, 11:57 AM
Gville350
Gville350's Avatar
If able, with the car running, I'd physically feel around that gap for any exhaust gases. More than likely you'll be fine though since using new gaskets.
Old 11-06-18, 01:46 PM
TakaM
TakaM's Avatar
I did at idle and felt no leak. Not sure if it leaks under acceleration. It's just the design seems strange as because spring is fully compressed, it no longer has the flexibility.
Old 11-08-18, 05:00 PM
EdgarLex
EdgarLex's Avatar
Is the other side lined up? When I was changing my exhaust I had to make sure that both sides were lined up before I could begin to tighten the bolts.
Old 11-09-18, 04:18 PM
TakaM
TakaM's Avatar
Yes, everything is lined up perfectly.
I've also tightened the bolts alternating both sides gradually so that it tightens evenly (my ocd nature).
I agree with MikeFig82 that Tanabe exhaust was designed this way (not sure why).
Old 11-12-18, 10:28 AM
EdgarLex
EdgarLex's Avatar
​​​​​​​Sorry for the late reply, but it is 100% normal. I did a F Sport exhaust install over the weekend and it looks just likes yours. I then checked on a stock IS350 and sure enough it was like yours and the F Sport install. I put my hand over the pipe and no leak. Enjoy your exhaust!
wasssaa805
Performance
11-13-15 03:06 PM
Duke02
Performance
03-01-10 11:42 AM
Kybball#1
Performance
09-04-09 12:23 AM
DropTopGal
Performance
09-12-07 07:11 PM
Quick Reply: Tanabe Exhaust Install help IS250
