Misfire when I fixed everything possible?
I've had this misfire on my 2002 gs300 I have new spark plugs and wires and DENSO ignition coils they are all installed correctly ,my compression is good , my fuel injectors are fine, but the strange thing is when I run the OBD reader one day it says cyl. 1,2,3,6 are misfire the next day only cyl. 5 is misfiring the next time I run the scanner it says cyl.1,2,3 are misfiring then there will be another day saying all cylinders are misfiring ,my car runs fine no stalls or anything scary like that and I've been told by my long time mechanic he doesn't feel a misfire neither ,I've been told by people and another mechanic that they don't feel no misfire like when they put the car on drive and hold the brake and hit the gas at the same time to feel if theirs a misfire ,please help ,and would it be possible that my ecu can cause a misfire ,I've been told something about that I can maybe have something electrical that's wrong NEED HELP
even though my gs has a v8 in it, I encountered the same thing with mine. but it only did it when first started and would set misfire codes randomly and never misfire when warm. luckily i have a air fuel ratio gauge in my car for monitoring air fuel bc of my supercharger. whenever it would set misfires codes when first started, the air fuel ratio would be too lean at about 16:1 which when first started on cold motor should be richer at 12:1. anyways, long story short, my fuel pump was on its way out. not sure why it would only do it when first started but it hasnt done it since.do you have an after market air intake? also, disconnect your battery and touch the cables together for 30 seconds than leave them disconnected over night. see if that helps.
Barna6vi
Performance
Jun 12, 2015 09:39 AM
Barna6vi
Mar 31, 2015 07:26 AM
