ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Performance (https://www.clublexus.com/forums/performance-186/)
-   -   2JZGTE GS300 Cranks, Won't Start (https://www.clublexus.com/forums/performance/793875-2jzgte-gs300-cranks-wont-start.html)
Toughtruck Aug 9, 2015 03:41 PM
Greetings Everyone,
After finishing my swap, connecting everything up, new spark plugs, oil/oil filter, transmission fluid, using the aristo fuel pump, car cranked, and ran like a champion. So, I followed a member who recommended swapping the pins on the grey plug on the aristo harness to make the shift lock/release, and the tach to work, which worked, but weird enough it would not fire up, and run any longer :uh: . I verified the crank, cam sensors are functioning. Verified there is 12volts to the injectors. Pulled the new plugs, and they were dark black on all 6. I couldn't imagine the timing getting off somehow, but what ideas do you guys have? I'm all out at this point, here's a video of what it is doing now. Any ideas, advice would be appreciated, thanks!
Toughtruck Aug 12, 2015 09:25 AM
Wanted to bump this thread to see if anyone has any input.
