SAFC2 install and settings on GS430 2001
hi, i am trying to hook up a safc2 on my 2001 gs 430. would any one have the correct pinout and initial settings? what type of maf sensor and safc2 maf#? would greatly appreciate it.
The ecu pinout sheet can be found on the internet and/or library. I found mine in my local library. I have a 400 so my settings/tune will not help you. Fyi, settings are almost never exact for the same car due to some having mods, some not and the overall condition/power output of the engine. I would just have a shop tune it for you. My local dyno shop tuned and dyno'd it for $200...1.5 hrs later. Good luck
^^You are right. In fact bloomslang can make you a custom harness so you dont have to cut off any wires. Its around $300 or less I cant remember.
But anyhow somebody still has to chip-in for the settings for SAFC II. You are right Rock-a-Lex that the settings on every car is different. But down here in dubai nobody is ready to touch a lexus. If i can get the intial settings to get the car started and get it to the shop, they will be more than happy to fine tune it.
Anybody?
Anybody?
Sorry for being a noob but i dont get it. How do i use the 4cyl setting? Is it a preset? Can i drive the car with it to the shop at least?
Yes, but you MUST do the initial setup before you turn the car on when everything is connected. Read the manual, the 4cyl piece is just one step from the initial setup. IIRC you turn your key to ACC and go from there with the setup instructions.
