PPE Headers and CEL Codes?
Old Jun 23, 2011 | 07:12 AM
Kybball#1's Avatar
Kybball#1
Default PPE Headers and CEL Codes?
Hey guys, For any of you gurus or people running these headers please feel free to chime in. I have been running these for a few months and have been battleing a few different CEL codes. I am running them with the PPE High Flow Cats and Joe Z Race Exhaust. Paul provided me some extensions with the headers, not the 90 degree ones but just some extended ones and I was throwing the P0420 and P0430 codes. Then Paul sent me a o2 simulator and it took care of those codes but then i was getting the P0606 code. Grrrrr... Paul has been working with me extensively to fix the problem. He is going to send me the 90 degree bungs and also a o2 conditioner. If you have any ideas or possible fixes to my problems, I am open to all ideas bc i really want to keep these. Thanks CL.....
Old Jun 23, 2011 | 12:13 PM
uaaction's Avatar
uaaction
sup bro.. i am running ppe and joez racing also but i have no cats and i am not getting any codes after i changed all o2 sensors... they are all brand new... take some pics and let me see how u welded ur extender...
Serg
ps. did you change any o2 sensors??
Old Jun 24, 2011 | 05:54 AM
06isDriver's Avatar
06isDriver
dibbs on buyin from ya if you cant get it solved!!!! Im serious.
Old Jun 24, 2011 | 11:41 AM
06isDriver's Avatar
06isDriver
you still getting the p0606? In all likelihood, it saved the data at the time the P0606 was triggered so that someone with an advanced reader could see engine parameters or what not.
Old Jun 24, 2011 | 11:43 AM
06isDriver's Avatar
06isDriver
and heres some more I found out about it:
"P0606 can be caused by the impedance in one of the o2 sensor not dropping when it should. There is no code for that specific error and that fault causes the ECM to think it has an internal issue. If you can see the data list look for the impedance of the o2 sensors, run the engine and watch to see if they start dropping, the one that doesn't drop is the one that needs to be replaced. Clear the codes and drive it for a while. Hope this helps."
Old Jun 24, 2011 | 05:04 PM
iSuxeL's Avatar
iSuxeL
That hole you drilled for the extensions have to be exact.
Old Jun 25, 2011 | 12:01 AM
ISF4life's Avatar
ISF4life
That why i waited for group buy, simply Paul was working on some ways to fixing those drilling holes and o2 sensor problems......... The new PPE Header required no drilling, just straight up install with o2 extension connect to the predrill holes and connect the simulator to the ECU box ... For people that want to keep the primary cats then weld those cats extension in between the mid pipe and the new header ( PPE header deleted those primary cats). or dont have to weld anything just using secondary cats.... from mid pipe..the reason u need to install simulator because PPE Header is much longer and o2 sensor is being moved away from the original spot ... the simulator triggers the system thinking that the o2 sensor still at the old location. that is the idea .. hope that help ...i'm very happy with my header
Old Jun 26, 2011 | 07:30 AM
IStnr's Avatar
IStnr
so who exactly has ordered the PPE headers with the 'new' o2 sim and had success? interested in specifically those that went straight from stock to the PPE with the newest o2 fix...no previous drilling, 90 degree extensions, etc..
if you were to order PPE now (and not have had any o2 modifications done previously), are we 100% sure the CEL wont be an issue? it seems like there are still some conflicting results... PPE input?
Old Jun 26, 2011 | 11:56 AM
flowrider's Avatar
flowrider
Veteran: Air Force
I have PPE headers on my F, but I have Hi-Flow cats so no need for the electronic O2 sim. A friend with another F had PPEs installed yesterday and he drove over to my house last night. He's running with no cats, he has a JoeZ. He's using the electronic 02 simulators. He has about 200 miles on the setup with no CEL.
Lou
Old Jun 26, 2011 | 11:07 PM
ISF4life's Avatar
ISF4life
installed PPE header with no cats about 3 weeks now and just got back from Santa Barbara , about 500 miles no Cel either , im using 02 simulator....
Old Jun 30, 2011 | 02:42 PM
juice14's Avatar
juice14
I have them installed without cats and I did install the extension, however I still get code P0157 Low voltage o2 sensor. I just bought a clearing thing and everytime it comes up (every 200-300 miles) I just clear it. If i leave it running with the cel I notice it just gets slower and uses up more gas. could be my imagination tho
Old Jun 30, 2011 | 03:54 PM
ISF4life's Avatar
ISF4life
juice14 u need to cal PPE and get the 02 simulator , that would do it... , no codes
Old Aug 17, 2011 | 03:10 PM
06isDriver's Avatar
06isDriver
Hey blitz, when you installed your headers with the o2 sim, did you just leave the 02 sensors in their normal positions?? Or did you plug them up and have no 02 sensors at all?
Old Aug 18, 2011 | 08:48 PM
Gaugster's Avatar
Gaugster
The O2 Sensors were in the stock location when I was using the Mazzuri Sim. Probably the same for PPE as its just and electrical thingy...
Old Aug 19, 2011 | 05:43 AM
06isDriver's Avatar
06isDriver
yeah I figured. After I read the instructions more carefully, I realized that you intercept the signals from the stock 02 locations and just feed the ecu what it wants instead of whats real.
