Car wont start! Fuel filter install
Old Nov 7, 2010 | 01:32 PM
TLcoats's Avatar
TLcoats
Default Car wont start! Fuel filter install
Hey guys. I just finished installing a new fuel filter into my GS. I followed the DIY to the T and bought the fuel filter from sewell parts. I reinstalled everything and went to turn over the car and it wouldn't fire. It was cranking but wouldnt go. I checked the fuel line to see if any fuel was getting to the engine and alot came pouring out of the pump assembly. Do you guys have any ideas what it could be? I would really appreciate the help so i could get my car started again. Thanks alot!
Old Nov 7, 2010 | 01:41 PM
Big Mack's Avatar
Big Mack
Cool
I know it seems obvious, but did you verify that the filter is installed going in the right direction? They are directional. And if not, don't sweat it - we all make mistakes and no one should give you grief for it.
Big Mack
Old Nov 7, 2010 | 02:21 PM
Och's Avatar
Och
Sounds exactly like what happened to me a couple years back. Search for my thread.
Old Nov 7, 2010 | 02:38 PM
TLcoats's Avatar
TLcoats
Hey guys. Thanks for the input. I took out the whole pump assembly again and dismanteled it and everything seemed like it was in the right place. Then i took a look at the old fuel filter to see if i missed any o-rings/washer's and sure enough on one of the inlet's i didnt see the o ring. So the fuel pump was actually pretty loose in the whole assembly. So i installed the o-ring and fuel filter and put it back in my car. It cranked right up after two tries and it sounds very very good. I almost want to say it made my car louder? But sure enough i go back into my garage to throw away the old filter and found this little rubber gasket piece on the bottom of the filter that i must have ALSO missed! Is this something that i have to put back on there and reinstall everything for the THIRD time? It seems to be running good right now.
Old Nov 7, 2010 | 02:41 PM
TLcoats's Avatar
TLcoats
Note to everybody looking to do this:
Make sure you look in every nook and cranny for parts before you go through the trouble of installing the new filter into your car!
Old Nov 7, 2010 | 07:40 PM
ThomasGS4's Avatar
ThomasGS4
I'm gonna be doing this soon.
Old Nov 8, 2010 | 07:01 AM
Rock-a-Lex's Avatar
Rock-a-Lex
So....How does the car feel TL? Does it feel the same other than the higher exhaust note? Also, when you get through a full tank please let us know the before and after gas mileage. Thanks!
Old Nov 8, 2010 | 06:20 PM
TLcoats's Avatar
TLcoats
Will do! I'm getting my car back tommorow morning from the shop, so i'll fill her up with 91 and keep you updated. Oh and here's a pic of the old filter, pretty surprising how nasty it was!
Yes, i cut this with a handsaw too. Took about 30 min, Your welcome!
Old Nov 8, 2010 | 07:39 PM
lo_dit's Avatar
lo_dit
good maintenance, might look into this soon
Old Nov 9, 2010 | 09:52 AM
sakataj's Avatar
sakataj
what? i cut mine with a hacksaw and took me like 1 minute maybe....
Old Nov 9, 2010 | 11:52 AM
TLcoats's Avatar
TLcoats
I used flosh to cut through it. It was working well except thedarn stuff kept braking...
Lol, I was using my dads hacksaw which literally had no teeth left on it.
jamestravo
May 19, 2017 10:01 AM
matts6887
RX - 1st Gen (1999-2003)
Dec 14, 2014 11:31 PM
funglenn
Jun 10, 2011 08:16 PM
stevengtt
Dec 21, 2010 08:19 AM
cwu
Jul 11, 2007 09:11 PM
