2jzgte vvti 6spd from supra??? gs300 possible?
Old Nov 7, 2010 | 04:56 AM
flexspeed's Avatar
flexspeed
Default 2jzgte vvti 6spd from supra??? gs300 possible?
i did a advance search to see if anyone have look into or did this swap, but didnt find much here. The question i have is as far is the engine drop in, but fabrication to the tranny, is the ecu be a plug a play with a couple wires changes like the aristo vvti or the wiring will be different since its from a last year supras?
im going to look into teh wiring to see the difference which anything is possible...if i can find a diagram.... will post update soon if i find some information but as for now, if anyone have any information to share be nice...
thanks
Old Nov 7, 2010 | 06:02 AM
fordsvtmfl's Avatar
fordsvtmfl
Try searching in the performance section, this has been covered multiply times.
Old Nov 7, 2010 | 06:13 PM
speedaddic's Avatar
speedaddic
you searched?
https://www.clublexus.com/forums/gs-...anual-now.html
Old Nov 8, 2010 | 11:22 AM
sakataj's Avatar
sakataj
Originally Posted by speedaddic
thomas,"i searched" is just a word people through around on here when they post new threads and didnt search
ALTHOUGH OP was asking about a 6 speed swap and adams is a 5 speed swap(I think.)Maybe most of the info is about the same,i would assume, but im not 100% sure so you can ask adam or TTURBOPIMP the details and since its hard to "read" sarcasm no thomas i wasnt trying to be rude to you either
TTurbopimp has a V8 swapped 6 speed though
https://www.clublexus.com/forums/gs-...ming-soon.html
https://www.clublexus.com/forums/per...d-is-done.html
yes OP it can be done just VERY expensive, just the 6 speed tranny is expensive
Old Nov 8, 2010 | 02:00 PM
flexspeed's Avatar
flexspeed
My main question is the ecu part.... this engine came off a supra in japan that have a vvti 2jzgte with a manual 6spd, i believe is from a RZ model... i did read adam thread which he is using the non-vvti model with a 6spd., my concern is the ecu part where... will it be a plug n play or have to play with wires... and believe its a 98 as in japan, 98 supra was introduced with vvti N/A or boost.... i rather get this swap with worth the money to it... if not going to work then my other option is to use the Haltech sports 2000 when converting to a manual with a 5spd or 6.
Old Nov 25, 2010 | 12:27 PM
JeffTsai's Avatar
JeffTsai
Better and easier to just go with a standalone if you're going to be doing 6spd. That's what I'm going to do pretty soon when I start building my race motor.
Old Nov 26, 2010 | 05:52 AM
cjames235's Avatar
cjames235
just a side note that hasnt been mentioned...... you will also need to convert the rear sump over to a front sump (you can use your stock GE pan i believe you will just need to drill and tap for the oil drain)
as far as im aware nobody has tried to use the supra harness and ecu...... maybe it works, maybe it doesnt........ i would say go standalone anyway
rush161
Performance
Feb 9, 2013 08:14 PM
GS300LUV
Feb 19, 2012 10:41 PM
okinawa2jz
Performance
Nov 17, 2011 09:04 PM
pass1914
Performance
Sep 13, 2005 07:54 PM
