srt intake
Old Dec 2, 2008 | 05:23 AM
onesickgs's Avatar
onesickgs
Exclamation srt intake
hello club lexus, please help me
i have a intake in my gs wich i dont like, some one on here is selling
*srt intake * what i will like to no is, to use the srt intake do i have to use a ecu ?, or can i just use the intake by it self
i do not want to mess with the wires at all !
i heard the srt intake b4 it sounds mean ! but i dont want it if i have to use it with the ecu !
Old Dec 2, 2008 | 05:29 AM
Stage3's Avatar
Stage3
To get the most out of the SRT, you need the ECU. I would venture to guess that it's actually going to HINDER performance if you just do the intake pipe and filter. If you don't want to do anything with the ECU, I would suggest the K&N unit, but then I would also suggest the Apexi SAFC to get the Air/Fuel mixture right...
Old Dec 2, 2008 | 07:42 AM
black_gs99's Avatar
black_gs99
you need to use the ECU supplied by SRT. their intake is much to large. if you dont want to hack up your lines get a wire harness so you can hack that one up and when your ready to take it off you can just pull off the harness.
Old Dec 2, 2008 | 09:50 AM
sam430's Avatar
sam430
Please share where you got the harness from and what part number it has. TIA.
Old Dec 2, 2008 | 09:55 AM
GILLEXUS's Avatar
GILLEXUS
What GS do you have?
Old Dec 10, 2008 | 07:53 PM
sonny 2jz's Avatar
sonny 2jz
im new at this i just bought a intake for my gs300 2001 and when i install it perfectly i then started the motor and my motor start to shake i test drove it around the block and it seems to lose power. then i uninstall it and put all the factory air system back and my car seem to be running smooth again...what is messing here?
Old Dec 10, 2008 | 10:46 PM
mex lex's Avatar
mex lex
Did you double check the wiring? Did you check the maf sensor, that it was installed correctly and not backwords, or loose, etc?
Old Dec 11, 2008 | 04:33 AM
fordsvtmfl's Avatar
fordsvtmfl
Did you reset the ecu? (disconnect the battery cable during the install) and mine always acts like that for a couple days (gets better and better) whenever I reset the ecu...so put the intake back on..let it idle for 5-10 min and then take it for a 10 min drive...it should be acting better then.
Old Dec 11, 2008 | 08:01 AM
sonny 2jz's Avatar
sonny 2jz
do i have to reset the ecu all the time? and why do i have to reset the ecu? will the ecu reset itself to match my short ram intake?
Old Dec 11, 2008 | 08:02 AM
sonny 2jz's Avatar
sonny 2jz
yes i double check the wiring everything was install perfectly...
Old Dec 12, 2008 | 08:49 PM
sonny 2jz's Avatar
sonny 2jz
Smile
can someone help me? plzzzz
Old Dec 12, 2008 | 09:16 PM
fordsvtmfl's Avatar
fordsvtmfl
I just reset it when I go from stock to CAI. Have you tried putting it back on and give drive it around awhile, and slow..and yes it will act like its drunk for the first 5-10 min of driving..and it takes 1-2 days of driving for it to sober up..lol
Old Dec 12, 2008 | 09:54 PM
sonny 2jz's Avatar
sonny 2jz
ok thanks man im do it but my worries is that it can damage my motor...lol
ivnnln
Performance
Oct 2, 2009 10:05 AM
marek955i
Performance
Sep 16, 2005 09:19 AM
FutureGS400
Performance
Jan 29, 2004 07:57 AM
Billbosh
Performance
Jul 9, 2002 07:44 AM
