What should I do next????
Well,
I upgraded my 98 gs400 with the following: S&S Headers Weapon-R Air Intake 3.76 Limited Slip Differential PI T/C Tanabe Touring Exhaust I am loving the way this car drives now! So much more fun and power! I am also waiting on some front and rear upper strut bars. But, what else can I do? I have to let the wallet cool off for awhile but before X-mas I want to get some more performance into this car. Thanks for all the info from this board its made my life and my car so much more fun! |
well torquemaster plugs would be a good idea. Apexi Neo to get a few extra ponies on a good tune. Unless you plan on shelling out some serious money for FI you've kind of hit the ceiling. However, you may want to look into high flow cats if you can pass smog in cali. Much outside of that, you've got a lot of it covered except suspension (coilovers or air, RCAs, etc.)
If you are looking for more power really the only thing that will give you a nice kick in the pants is a SAFC. With all the mods you have I bet you would see nice numbers from a good tune. Id go with the apexi neo personally.
Before you splurge all your money into power adder, you might wanna invest in some suspension parts. To start off, I recomend the daizen steering rack bushing along with front suspension polyurethane bushing. That will be give you a totally fun ride. Then after that, some properly dialled in coilovers.
and before u splurge all the money on suspension...........try doing the upgrade most people over look and the one that matters most. BRAKES......some simple pads, synthetic fluid, good rotors, and some steel braided lines or some supra calipers or a BBK but these are overkill. before you start adding power and suspension make sure you have a system in place 2 handle the upgrades you do. all the hp and grip wont do you ANY good if you cant stop! oh also let me ask...since u said u just got s & s headers YAWN, whats your opinion of them?
Originally Posted by Yawn
(Post 4003686)
Well,
I upgraded my 98 gs400 with the following: S&S Headers Weapon-R Air Intake 3.76 Limited Slip Differential PI T/C Tanabe Touring Exhaust I am loving the way this car drives now! So much more fun and power! I am also waiting on some front and rear upper strut bars. But, what else can I do? I have to let the wallet cool off for awhile but before X-mas I want to get some more performance into this car. Thanks for all the info from this board its made my life and my car so much more fun! Torque Master spark plugs - new ones should be here any day now Apexi Neo - Got some great results from this A/F controller My S&S headers are still down in my basement waiting to be installed. lol. When I have the new plugs and headers installed it's back to the Dyno for a re-tune on my Neo...hoping to see 290whp or more! GL!:D |
Originally Posted by sakataj
(Post 4005314)
One unrelated thing that may be a concern is that with the new LSD and the Tanabe Exhaust, there is very little clearance between the two. I hope it does not become a problem where I will have to have a shop re-route some of the exhaust tubing. |
Originally Posted by Rock-a-Lex
(Post 4005458)
:thumbup: I pretty much have the EXACT same "performance" setup as you. Only I have:
Torque Master spark plugs - new ones should be here any day now Apexi Neo - Got some great results from this A/F controller My S&S headers are still down in my basement waiting to be installed. lol. When I have the new plugs and headers installed it's back to the Dyno for a re-tune on my Neo...hoping to see 290whp or more! GL!:D Hurry up and intall them!! I wanna know if you hit that 290 mark |
i would suggest:
-Torque converter -Light Weight Drive Shaft -A Good PiggyBack ECU -Your Pefferd Racing Spark Plugs -Maybe a Fuel Pump as well and when the injectors duty are to the max injector upgrade would not be a bad idea at all ! im wondering what is PI T/C ? (somthing to do with Traction Control am Assuming) |
It's a high stall torque converter made by Precision Industries. The second gen. GS owners mainly buy these converters set anywhere from 2800 - 3200rpm stall (stock is set to 1800rpm). I have a 3000rpm stall...which pretty much leaves a 15' stretch just by mashing the gas; so now I need wider rear wheels/tires for more traction. lol
Originally Posted by Donuts
(Post 4009150)
i would suggest:
Originally Posted by alexus_300
(Post 4010902)
half of the stuff you have on your list is not needed at all. The light weight drive shaft will do nothing along with fuel pump and injectors as you're not ramming enough air into the a/f mixture to compensate for the upgrade. Those items are only needed if you are boosting. Most people don't realized how important your suspension is in a vehicle. You can make all the power you want but if you can't put it to the ground, then you'll just have a nice black skid mark on the ground to look at...:sad:
...your right! But, in my case I still have a nice Bilstein PSS coilover setup and still can't get traction; my tires are a little worn now too though.
(Post 4011430)
thats your issue. I have a bone stock (power wise) GS4 with Proxes4 and I can break them loose. When I had the Proxes T1S, I never had issues with traction. Screw all season, get a set of Proxes T1R, and run snow in the winter. |
(Post 4009150)
i would suggest:
-Torque converter -Light Weight Drive Shaft -A Good PiggyBack ECU -Your Pefferd Racing Spark Plugs -Maybe a Fuel Pump as well and when the injectors duty are to the max injector upgrade would not be a bad idea at all ! im wondering what is PI T/C ? (somthing to do with Traction Control am Assuming) -OP already has a Torque Converter -driveshaft won't do a damn thing. -piggyback ECU is overkill unless FI, an Apexi Neo a/f controller is sufficient -these lexus engines are particular about plugs, already suggested a good set (torquemaster) -fuel pump and injectors, again will do nothing without FI. use your head, and read what has already been posted. Every piece of information you posted was either already covered or useless. |
