'00 GS4's with Nitrous, PICS?! [& recommendations?]
gonna plan on buyin' a kit. thinking 100 shot.
do i go with wet or dry? do any of you with it have pics of the set up? should i go more than 100 shot? recommendations on what brand to go with? i was thinking ZEX anything else i should be concerned about before jumping into this? lol |
Transmission. Usually when you put a little bit more power to it you have to worry about the tranny. Probably get a valve body upgrade.
I say get a wet if you plan on spraying anymore than a 50 shot. However; you will have to mod your fuel line or fuel rails for a wet system. Almost all nitros systems are the same, but if you get the ZEX kit, make sure you don't get the dry shot with the nozzle on the filter.
Also, if you want a 100 or higher shot, I highly recommend a RPM switch. |
are you getting rid of the sc?
no i'm addin' nitrous to the s/c.
Originally Posted by Kharizma
(Post 3026044)
Wet set-up is going to be your best bet because it adds the correct mixture of nitrous and fuel. Very easy to tune by just adjusting the jets. I have the Zex on my GS400 and run the 125 no problem. Engine sounds great and it drops about a second and half off my 1/4 mile and about a second off my 0-60. I have a Window switch as well which I think is a good precaution because our car shifts by cutting fuel. Zex apparently will cut the nitrous if it feels a drop in fuel pressure, but I wouldn't bet my motor on it.
Originally Posted by jesod
(Post 3038488)
I'll take a picture and post for you if you want. It's pretty simple if you know where to tap it.
pic of jesod's car
https://www.clublexus.com/gallery/da...opy_Large_.jpg
camera phone video of the car 0-60 http://www.youtube.com/watch?v=WEL-ZKsAXSY |
:thumbup: cool. At what revolution is flow cut?
6350. I've got the window switch at 6200.
i'm spraying on top of the FI
Originally Posted by LCSC
(Post 3047573)
http://www.youtube.com/watch?v=WEL-ZKsAXSY karizma, if you're planning to add a 100 shot to an already boosted, stock motor, you'd better have someone who really knows what they are doing set it up. you should also really have forged pistons. |
| All times are GMT -7. The time now is 09:59 PM. |
