IS250 airflow
Hey guys,
i took the cover off my engine bay this morning and notice from that and also by looking through the front grill that most of the front grill is blocked off by some plastic
and once i took the engine bay cover off, i notice the port for the air to come into the air box was situated on the top where i would think its not getting much air flow since the front grill is blocked off
am i correct? would removing the stuff blocking the front grill give it better air flow?
heres a picture of what im talking about, the air scoop is circle in red and the 2nd shot shows how the front grill is covered up
the last pic, behind the grill where the L emblem is, there is nothing blocking the airway
the 2nd pic has a piece of plastic blocking it
i was just wondering if many IS250 owners have removed this piece of plastic behind the grill
I wouldn't say that:
1. Cold air is always a good thing.
2. The change improved the situation in any way.
A lot of stuff about airflow is counterintuitive. Gas molecules are funny things and they don't always behave the way you think they should.
You can easily make 206 hp with a 2" intake tube. So, about 6 square inches of cross section will flow more than enough to make 206 hp. There is easily that in the openings in our plastic airflow management piece.
If you really want to see if you made a difference, monitor intake air temperature using the OBDII port.
And don't forget, warm air improves thermal efficiency at part throttle, sometimes a lot.
Plus all the short ram intakes like the K&N don't take advantage of the stock air intake which is basically a fairly good CAI.
IMHO, a solid aftermarket exhaust for the 2IS would incorporate the stock CAI, modify the pipe from the stock CAI to the airbox to be smoother (although its almost optimal now), have a high flow airbox to a JoeZ style tube.
Ok sounds like I might have to homebrew this since all it'd require is:
a) JoeZ tube (got one),
b) high flow filter in the airbox (got one),
c) checking the stock CAI pipe and seeing if there are any more optimal designs (which someone did in the past, think the result was there could be a better design, less bends),
d) potentially taking out the extra filter in the stock airbox (although results have been very inconsistent here, and no extensive gains testing has been done).
Javier
