ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   Performance (https://www.clublexus.com/forums/performance-186/)
-   -   I kicked my throttle body's arse! (pics) (https://www.clublexus.com/forums/performance/222021-i-kicked-my-throttle-bodys-arse-pics.html)
GUNRU-GS4 Jun 14, 2006 06:21 PM
On the way home from work today I decided to pick up some throttle body cleaner and clean her up. I have 90k on my 98 GS4 and it looks like the throttle body has never been cleaned. I also cleaned the MAF sensor and my K&N filter recently. Hell it feels more responsive and runs better than when I had an intake on there. It's like a $2.99 mod! If you have higher mileage and haven't done this get off your butt and do it! I hooked the battery back up and started it up and it ran at higher rpms (1000) for about 5-10 mins. Then it settled down and is really smooth. It was really full of carbon build up and I only use Amoco 93 octane.
it's dirty in there
https://www.clublexus.com/gallery/da...dium/dirty.jpg
https://www.clublexus.com/gallery/da...ium/dirtyy.jpg
the remains of the battle
https://www.clublexus.com/gallery/da...medium/stp.jpg
ahh so clean
https://www.clublexus.com/gallery/da...ium/clean1.jpg
bighitbike Jun 14, 2006 06:27 PM
Niiiiiice, one time I did that to some guy making fun of me....He didn't turn out as shiny as this! His eye was pretty close though.
tmf2004 Jun 14, 2006 08:07 PM
Mine looked like that at 55k.. These cars must build up some heavy carbon.. I'm going to do it again at 65k.. Nice job.. :thumbup:
TexasGS Jun 15, 2006 05:24 AM
I did mine when I put my SRT in. I was suprised how dirty it was. I think this is something everyone should do if they haven't done it.
DASHOCKER Jun 15, 2006 05:34 AM
Nicely done :thumbup: Yup, a dirty TB can decrease performance. Good thread.
chuckb Jun 15, 2006 11:32 AM
did you spray it right in there or just wipe it with the rag?
GUNRU-GS4 Jun 15, 2006 11:45 AM
I was worried about spraying it in there so I just sprayed cleaner on the rag and wiped it clean. A lot of the crap on the inside was cooked on so I used a toothbrush to scrub .
bigL Jun 15, 2006 12:04 PM
Agreed.I cleaned my TB and intake when I replaced my starter and couldnt believe the difference.
JohnGS4 Jun 15, 2006 12:10 PM
More pics of where to access throttle body?
John
GUNRU-GS4 Jun 15, 2006 12:14 PM
John
Pop your hood and you see the big plastic tube going from your airbox to your engine. The throttle body is where the plastic tube connects to your engine. My pics just show the front of the engine with the intake off.
oohpapi44 Jun 15, 2006 12:25 PM
Gunru,
Maybe you should post step by step for MAF sensor cleaning since it can be damaged fairly easily.
Dx3 Jun 15, 2006 12:49 PM
Just spray it in there and then start the car and bolow all the gunk out!
Jonny
DASHOCKER Jun 15, 2006 12:55 PM
You guys should never spray directly into the TB. You can damage the the MAFsensors within the TB. The threads in there are very fine. It is best to saturate the rag and rub the walls of the TB. You can spray the TB plate when it is closed though to get the build up off the plate.
PhantomZX Jun 15, 2006 04:14 PM
Why does carbon build up on the throttle body plates?
I thought the fuel injectors were past them...
STONER Jun 15, 2006 08:20 PM
Read this and stopped by Advance auto on the way home. Took about 15 minutes to get the TB spotless. My car has 82K and I don't know if it's ever been done. Should it improve response, mpg, neither or both. I disconnected the - terminal while I was doing it, so the ECU probably reset anyway. I'll report back.
