Split Second......Hmmmm?????
Old Nov 29, 2005 | 06:53 PM
trbopooh's Avatar
trbopooh
I'm going to run the RMM SC kit with the 3.0 pulley. I think it's supposed to run 8lbs of boost. I'll give split sec a call later in the week. Thanks.
Old Nov 29, 2005 | 08:30 PM
jgscott's Avatar
jgscott
Heres a PiggyBack that works on any 1UZFE. It controls timming, A/F, Boost, Nitrious, and can have 2 Diffrent Maps. Everyone overlooks it and there are alot of misconceptions about what it can and cannot do. I have one in my car controling my Zex kit. Map 1 is normal with A/F and timming corrections. Map 2 is Nitrious, Progressive, Rev limit cut off, retard timming, deleted auto shift retards between gear changes.
My next step is to try and defeat the Mass Air Flow sensor with it.
http://www.dynoperformance.com/artic...ails.php?ID=10
Old Nov 29, 2005 | 10:01 PM
trbopooh's Avatar
trbopooh
Hmmm...another option to look at. Do you know if this will work with vvti v8 motors? Thanks jgscott.
Old Nov 29, 2005 | 10:18 PM
jgscott's Avatar
jgscott
Yes it will.
Old Nov 30, 2005 | 07:06 AM
Lextreme's Avatar
Lextreme
JG,
That is a Unichip correct?
Old Nov 30, 2005 | 07:09 AM
morris's Avatar
morris
To tell you the truth I dont think you need fuel management with the 3.0 pulley and Its doubtful that you will see 8 psi with it. Probably more along the lines of 5, if I remember correctly.
Old Nov 30, 2005 | 08:15 AM
Dr.G's Avatar
Dr.G
ditto...maybe 6lbs...2.87" pulley will more likely get you around the 8lb mark. SAFC2 will be capable of handling, just be sure to upgrade your fuel pump and FPR for reassurance.
Roenick7 was the one to use Split Second, and this was a direct quote from him that I got awhile back when discussing whether or not it was worth his time and $..."Split second worked better than SAFC-2 HOWEVER IT TAKE SEVERAL DYNO RUNS TO TUNE IT WHERE YOU CAN HURT THE CAR; IF IT RUNS WITH THE SAFC STAY WITH IT, not worth the extra money and the extra 5-10RWHP that you may pick up is not worth it in that 4000lb car"
Old Nov 30, 2005 | 08:20 AM
morris's Avatar
morris
Now if you want to hit 10-12 psi, I can help you get there, I've got a set of custom pulleys that will do the job.
Old Nov 30, 2005 | 02:34 PM
trbopooh's Avatar
trbopooh
Thanks Dr. G & morris. I guess I'll stick with the tried and true.
Old Nov 30, 2005 | 03:28 PM
Dx3's Avatar
Dx3
With that kit and a 2.87 pulley I was making 8psi.
Jonny
Old Dec 3, 2005 | 11:48 PM
jgscott's Avatar
jgscott
Originally Posted by Lextreme
JG,
Yes it is Unichip.
Old Dec 5, 2005 | 09:55 PM
Lextreme's Avatar
Lextreme
Any news on the split second unit?
Old Dec 7, 2005 | 07:38 PM
Dx3's Avatar
Dx3
Bump - anyone else have any input?
Old Dec 8, 2005 | 11:18 AM
Lextreme's Avatar
Lextreme
I know this program pretty well now. If anyone need help on the base program or would like to learn how to tune it, please let me know. I can share with you my programs or i can help you set one up.... i am open to help.
Old Dec 8, 2005 | 11:29 AM
Dx3's Avatar
Dx3
WIsh you were a little closer!! I need a good tuner!
Jonny
