LMS SC results/NEW UPDATE w/jbrady Headers
WOW!!! So far the results are great. 313 whp and 300 pounds of torque @ 6.5 psi. I know that this run is not the full potential of this set up. Have done runs at night where I am seeing 7.34psi. I "think" I am getting closer to 320-325whp. I am having the jbrady (S&S) headers put on and the XS ignition booster installed monday, we will do another dyno to see what the gains are. I am so happy with this setup :D
It was about 70 degrees in the shop, great day for a dyno :woot: https://www.clublexus.com/gallery/da...m/DSC00385.JPG https://www.clublexus.com/gallery/da.../DSC003741.JPG https://www.clublexus.com/gallery/da...m/DSC00379.JPG https://www.clublexus.com/gallery/da...m/DSC00377.JPG https://www.clublexus.com/gallery/da...m/DSC00384.JPG |
Congrats on your results. Do you have a close up of the dyno sheet?
Thanks, Mike |
Thanks, Mike Look under my photos. It allows you to blow up the picture. |
This is with an intercooler and what size injectors and what tuning tool? Nice number though.
Car looks hot !!!!!!! :D Iam also drunk and its 2:47 a.m. :woohoo: |
I have the XS engineering ignition power pack upgrade and so far no problems. Easy to install. Maybe you should do the header install, then dyno and then do the power pack. just to see the overall results.
nice numbers and clean install... a BIG :thumbup: to LMW!!!!
Congrates JP430 for getting the LMS GS430 S/C kit. :thumbup: :eek2:
Are there any other GS 430 S/C kits done? What A/F ratio did they tune it to? Did you go w/ the Zeitroincs wide band display? See if LMS wil give you your dyno run file on a disk. You can disply it alot better. |
Are there any other GS 430 S/C kits done? What A/F ratio did they tune it to? Did you go w/ the Zeitroincs wide band display? See if LMS wil give you your dyno run file on a disk. You can disply it alot better. Thanks gillexus I am still learning about FI. The wide band displays 14.00-14.50 when not boosting, when really getting on it, it drops to 10.00-11.5. As far as who makes the wideband display :uh: Good idea about putting it on disk :thumbup: |
I thought that LMS was using dynojet but If mamory serves me right they have mustang dyno. I'm not sure what you need to read their file if it was dynojet , I have the software to thafile.
I think the SC430 they did was did 323hp & 313tq. Each car is different. do you have an exhaust on yours? have you had it dynoed before? Now all you need is some braided lines and your engine bay will really look sweet. I like your gill. :) TRD? |
I think the SC430 they did was did 323hp & 313tq. Each car is different. do you have an exhaust on yours? have you had it dynoed before? Now all you need is some braided lines and your engine bay will really look sweet. I like your gill. :) TRD? https://www.clublexus.com/gallery/da...m/DSC00325.JPG |
I've always been in Colo.
Even if you leave your cover on The braided lines will look nice. I'll send you pics of what I did and did not spend a mint on it. Where did you put your I-mange and Zeitronix unit? |
I've always een in Colo.
Very nice!! :thumbup:
great job bro.. i like the numbers and i knew the overall design was made to work and work well.. i am not after high hp numbers nor after destroying a 5k+ tranny either so for me in the 320-350 to wheels numbers are fine.. imagine his numbers were done on stock injectors and a fmu .. i always knew it was alittle over kill for i found out that the duty cycle of out stocks were not maxed out and had suffient room to play with if you are not after higher numbers.. its certainly nice to know with the procharger and a larger fuel pump bigger injectors and slight pulley change 400 rwhp can be safely achieved :thumbup: again great job luxury motor
now i am waiting for steve to finish my stuff or decide what direction he and i are going.. ;) can you post some closeup shots of the entire s/c setup from different angles and btw the explosion front with a intercooler of that size with inlet and outlet on either side looks sweet , although one suggestion , get a quality matching mesh to mount between the inetcooler and bumper to give the front area alittle more stealth look .. in other words with your polished intercooler those who know will see it clearly and those who just got a arse whipping will sit there :uh: again great job , and i hope i am next ;) steve |
