2jz-ge injectors
I'm looking for some injectors for my 2jz-ge.
What kind do I need? I'm probabaly looking for 440cc.
Also, what size is the stock TT injectors? Will it fit on the 2jz-ge? Reason i'm asking is because my friend will be upgrading his TT injectors soon and i was looking to pick up that stock set from him.
Injectors from a 7MGTE (MKIII Supra Turbo) will fit perfectly and the clips will plug right in. They are 440 cc/min
BUT!
they are low impedance and you will also have to wire in the resistor box. Do not forget this important step or you will burn out the drivers in your NA ECU....
BUT!
