Need some feedback on this LSD im about to purchase
Old Aug 4, 2004 | 12:34 PM
TLW's Avatar
TLW
Default Need some feedback on this LSD im about to purchase
i was on i-supra forum looking for
an LSd
when someone contacted me and said he has one straight from
toyota never been used or filled
heres a pic let meknow what you think
johnny
oh he wants a $1000 for it i called toyota and they said they could get me one for $1650
and it would take like 3-4 weeks
Old Aug 4, 2004 | 12:46 PM
rominl's Avatar
rominl
exclusive matchup
not been used?! how does he explain the rust and also the dust on the top then?! if it's a new unit i would expect it to be cleaner? just curious. the one from FutureGS400 was a lot cleaner imho
and i am also curious, how are you sure it's a rear end with lsd in it? part number on the rear end or what? i guess my question is i am not sure if all differential from supra looks the same
Old Aug 4, 2004 | 12:58 PM
TLW's Avatar
TLW
henry just talked to him
said its from humidty and being around the shop
offered him $900 shipped
told me he'd think about it
dont want to spend all that money and get a headache
thanks
johnny
Old Aug 4, 2004 | 01:07 PM
rominl's Avatar
rominl
exclusive matchup
ok now the only thing is to see how you can prove it's a diff with lsd then? only a certain yrs of supra auto rear end has the 3.76 with lsd. i believe it's 94-95?
Old Aug 4, 2004 | 01:37 PM
TLW's Avatar
TLW
oh ive done my research
the other years96-98 had it as well but i was an option So you have to be careful)
i read someone's post where they counted the 49 teeth
i think they bought it from canada doe 600 shipped but the guy told me 850 so
im going to be patient
Old Aug 4, 2004 | 09:17 PM
rominl's Avatar
rominl
exclusive matchup
what is canada doe?
i know a new one is 1400 bucks easy, so there you go the reference
it used to be very cheap, but not anymore
Old Aug 4, 2004 | 09:18 PM
rominl's Avatar
rominl
exclusive matchup
btw what's the part number of the 3.76 lsd anyway?
is it printed on the rear end itself?!
Old Aug 4, 2004 | 09:45 PM
TLW's Avatar
TLW
what is canada doe?
i
sorry henry i was typing to fast
here's somethings i found while looking for info
the first up until the ******"s is from nudder's post about where he got it from hence canada doe
and the rest is just random info
First, thanks to Adrenaline Motorsports in Canada, the source of my '95 1/2 Supra TT rear. Turns out the unit is in excellent condition, just as advertised. Thanks Phil!
Other posts have suggested that the real cost is about a wash, I would tend to agree. It would seem to be more a choice of whether you want the TRD with the clutch pack and standard gearing or the Supra/RMM torsen type with 3.76 gearing. Main difference is that you can find the RMM rear used much easier (Supra Auto version that is). I got mine for $600 plus shipping.
Supra TT 3.76 Auto : year 93.5-96 has LSD from factory
Supra TT 3.76 Auto : year 97+ has NO LSD from factory, not even optional, (I know that now) I have the 97 diff.
I've summarized all of the MKIV Supra differential specs and applications below:
Open 4.272 Ratio (11 teeth pinion, 47 teeth ring): Standard differential for 93-96 normally aspirated automatic and manual transmission Supras.
Worm-gear Torsen-type LSD, 4.272 Ratio: Optional differential for 93-96 normally aspirated automatic and manual transmission Supras.
Worm-gear Torsen-type LSD, 3.769 Ratio (13 teeth pinion, 49 teeth ring): Standard differential for 93-96 TT automatic transmission Supras.
Worm-gear Torsen-type LSD, 3.133 Ratio (15 teeth pinion, 47 teeth ring): Standard differential for 93-98 TT manual transmission Supras.
Open 3.769 Ratio: Standard differential for 97-98 TT automatic transmission Supras.
Helical-gear Torsen-type LSD, 3.769 Ratio: Optional differential for 97-98 automatic transmission Supras.
Open 4.083 Ratio (12 teeth pinion, 49 teeth ring):: Standard differential for 97-98 normally aspirated manual and automatic transmission Supras.
Helical-gear Torsen-type LSD, 4.083 Ratio:: Optional differential for 97-98 normally aspriated manual and automatic transmission Supras.
think the 3.769 ratio will offer optimal performance for the GS4. It is debatable whether or not the worm gear type of 93-96 is "better" than the helical gear type of 97-98. I would take either at this point if I found the right deal.
These differentials are not that plentiful in the "used" market right now. Expect to pay $400-$600 used and $1500 new. Furthermore, I've found most sellers are not wiling to remove the differential cover to confirm LSD and ratio and send pictures. If they are unwilling, this means they probably have something to hide. As you can see from the specs / application list, there is a wide variety of diffs available for the MKiV Supra so it would be easy to receive a diff other than what you paid for. Buyer beware
https://www.clublexus.com/forums/sho...ighlight=teeth
Old Aug 4, 2004 | 11:04 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
I bought mine for 450.00. 3.76 with LSD. I would pass on this one for that price and search the Supra forums where I found mine. I placed a WTB ad and received 5 responses.
Lee
Old Aug 4, 2004 | 11:49 PM
rominl's Avatar
rominl
exclusive matchup
maybe i should get the 4.2 ratio coz' of my 20s
Old Aug 5, 2004 | 09:51 AM
Hameed's Avatar
Hameed
EV ftw!!!
The one I got from TTurboPimp (3.76 gear with LSD) looks exactly like the one you posted above. (Not that that info helps you .........)
Old Aug 5, 2004 | 01:56 PM
aliga's Avatar
aliga
Former Sponsor
just turn the shaft to see if the half shafts turn in the same direction.
Old Aug 5, 2004 | 03:45 PM
rominl's Avatar
rominl
exclusive matchup
not sure about thatt. coz' both wheel half shafts have no traction. i believe they both go the same direction if they have traction?
Old Aug 5, 2004 | 03:59 PM
aliga's Avatar
aliga
Former Sponsor
i am 100% sure about this, with a non lsd, if you turn the shaft, the half shafts go in opposite directions.
Old Aug 5, 2004 | 07:33 PM
TLW's Avatar
TLW
have to do some more investigating ill post more tomorrow
sorry
johnny
