When I let off the gas above 20-30 mph it bucks
So been I bought my sc last month been doing all the normal tune ups spark plugs, wires, fuel filter/pump but when I drive for instance anything over 30 if I let off the gas it bucks or shoots down in rpm more than it should say I was at 2300 it would shoot down to 2k if I let off the gas fully and slows the car down more like driving stick any ideas??
thanks guys any help greatly appreciate |
Hello,
It sounds normal for an automatic transmission, it has an ability to engine brake as well. If it brakes a lot faster than it should, then the source of your issues can be something other than engine or transmission, seized brakes or a bad wheel bearing could result in a similar problem. Check that all 4 wheels spin freely, the brake fluid looks clean, and all the calipers look solid with no tears in the seals. Hope this helps and best of luck! |
| All times are GMT -7. The time now is 02:41 PM. |
