AR5 Sc300 Swap
Update: Ok Im now buying some parts for the swap! I was looking on ebay for a W58 Flywheel and Presure plate and I came across the brand LUK which is supposed to be oem. Luk also offers a presure plate and clutch kit on Amazon. I think I am going to go with this brand for my flywheel and presure plate what do you guys think? Because I am on a budget for this swap so this looks like it is the most cost effect way of doing it. I could go with a Exedy presure plate but I believe I need the clutch release bearing from the w58 for my Ar5 swap if anyoine knows please let me know it has been driving me crazy and I cant find anyone that mentions it.
Flywheel :
( https://www.ebay.com/itm/For-Toyota-...l/283721140070 )
Pressure Plate :
https://www.amazon.com/LuK-16-086-Clutch-Set/dp/B000CI8XSG/ref=sr_1_1?dchild=1&keywords=clutch&pd_rd_r=1195e6e0-7dfc-4b46-8c8d-6e67b3a79060&pd_rd_w=MBx5h&pd_rd_wg=jMvW9&pf_rd_p=314cba8a-9ad7-41b6-886d-7d421b3ca92e&pf_rd_r=FDKS11BW9K7XZZ621EYM&qid=1588538852&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&s=automotive&sr=1-1&vehicle=1992-75-1006-20--7-6-7-4904-1787-1-1-1897--&vehicleName=1992+Lexus+SC300
Flywheel :
Pressure Plate :
I also found a presure plate on rockauto from the brand M-Pact couldnt really find any reviews from 2jz users only other miata etc forums mentioned them.
https://www.rockauto.com/en/moreinfo...0878&jsn=10878
LUK is a very reputable OEM supplier of flywheels for several manufacturers from Mercedes-Benz to BMW to in limited cases Toyota.
To the best of my knowledge the LUK OEM flywheels for Toyota are primarily dual-mass units for the Supra Turbo Getrag V160 and V161 and for the W55 transmission found in the IS300 M/T.
The OEM single-mass flywheels for the W58 are not (I think) LUK brand but probably Aisin/Toyota. But I may be wrong?
Flywheel :
Pressure Plate :
https://www.amazon.com/LuK-16-086-Cl...92+Lexus+SC300
Flywheel :
Pressure Plate :
I have a Luk repset rs4 clutch kit in my Audi and it's buttery smooth for a clutch that holds decent power... but that could be cause of the PP design and dual mass flywheel.
I liked it so much I actually got a 92-96 camaro Luk repset clutch kit for for my t56 to small block chevy conversoin. That clutch feels good too, I haven't fully broken it in yet but so far no complaints.
Hi everyone just wanted to post a update on my swap, so far I have gotten all the parts like the pressure plate , flywheel etc I just haven't had much time lately. I just had a quick question about the clutch release bearing i cant seem to find anything about this anywhere but what bearing would I be using in this case? I have the AR5 tranny with the W58 Flywheel and Pressure plate with a chevy s10 clutch disc so would i be using a chevy s10 bearing or w58 bearing.
