Overly fast idle at cold start up.
Upon starting cold the 94 SC300 runs up to 1500 RPM which seems excessive. You get a real bump when slamming it in gear. Is this adjustable?
Bob, my apologies. I should have stated that IAC-V stands for the IDLE Air Control Valve. Check into that unit and if necessary the wiring going into it and the condition of the engine harness plug that goes into it. If it is malfunctioning, the OEM part should still be available. Same for the harness plug or repair wire terminals with seals.
If the OEM IAC-V is not available try looking it up on Rockauto under the Standard Motor Products, Airtex/Wells or other aftermarket brand.
Bob - that's about what mine warms up at during a cold day here in Denver. If it idles normally closer to operating temp I wouldn't sweat it any.
Keeper of the light
The TPS sensor is adjustable. rotate it slightly....... SLIGHTLY..... and see if it helps. You can change the idle RPM and shift immediately by unscrewing the sensor and making minor adjustments to it's position. I got rid of my shift issues 5 years ago or so with a simple change to the position of the sensor. Do not do that without marking it's original position. One way makes it shift harder, one makes it shift softer.
It's an after effect of doing so, it's not it's intended purpose. "it works". Meme attached for Lexus technicians.
Lexus082
Performance & Maintenance
27
01-20-08 01:51 PM
