SAFC Mistakes/Corrections on 96 SC300
The SAFC documentation had a lot of errors regarding the install on a 1996 SC300 OBD2. I will list the mistakes and corrections so future installs by cl members will be a bit smoother.
1. The sensor is not Karmann, it should be HW-12 2. The rpm signal is not on B58, it should be B57 3. The pressure signal is not on B62, it should be on B66 |
1 Attachment(s)
ECU Diagram
1 Attachment(s)
ECU Diagram 2
thanks Gazi..
doesn`t obdII restrict the advantage of using a piggyback? I am not sure where I heard that, but I remember hearing that using it on an obdII would limit how much the afc could compensate??? just throwing this out here, hoping that someone might give me a little leson:D
Please excuse the bringing up an old thread for no reason, but I wanted to add a few words in here so this comes up in searches.
Keywords: pinout pin pins ~Alan |
Do we know if the same mistakes are on the OBDI for the SC400?
Jonny |
Hmmmm.....I know for sure that the OBDI sould be set to Karmann Vortex instead of Hot-Wire, but that's about all I know.
~Alan |
~Alan Where can I get the Karmann Vortex settings? Thx man, Jonny |
It's not about "getting" the settings, it's about setting the sensor type to Karmann instead of HW (Hot-Wire).
When SupraForums comes back up, search their Naturally Aspirated section for SAFC. Try to filter out the bull**** and you'll find the right answer eventually. :) ~Alan P.S. I've come to realise that on SupraForums, any post that begins with "In my opinion..." should be skipped. :p |
