Rear End very unstable after rim & tire change
Old 02-10-18, 03:10 AM
Vitamin-SC
Vitamin-SC's Avatar
Default Rear End very unstable after rim & tire change
Car: 1999 Sc400
Let me start by saying before I installed the wheels I was on stock 16 "rims and tires or all oem stock for 99 sc400 .Ok got a set of stock IS350
Staggered wheels 18 x 8 & 8.5 since i'm not lowering the car.I purchased 2 new 225 45 18 for the front ,the rear came with a set ,255 40 18 used but had great tread so I went with it .
My old setup "16" the car ran true up to about at most speeds 70 and above+
Since installing the wheels the Rear of the car is Very unstable in the rear at speed 50+, higher the speed the more unpredictable it becomes ,to a point Its unsafe .I can only imagine how it would be on a Rainy Day on the Interstate highway
best way to describe it would be ,under inflated tires ,blown shock /strut . Its drifting side to side like the rear has steering
so far I've only done visual inspection at bushings and bounce test shocks ,looked for anything broke,or missing bushings "nothing obvious"
I dont really want to just throw random parts at it
The car has been well maintained Has 240k miles on it I've only had it my possession 9 months
Old 02-10-18, 06:04 AM
logix7
logix7's Avatar
did you have an alignment done since changing the rims? it couldnt hurt. and how much tread is actually left on the rears?
Vitamin-SC (02-10-18)
Old 02-10-18, 06:20 AM
scsexy
scsexy's Avatar
put your stock rims and tires back on and see if it goes away would be the most obvious thing to do in my eyes. It would eliminate the wheels as the concern. If it does go away you know the new rims are bent or tires are bad.
Vitamin-SC
Vitamin-SC's Avatar
No alignment yet but rears have about
6-7/32
Old 02-10-18, 08:14 AM
Vitamin-SC
Vitamin-SC's Avatar
Just check wheels of or play in bearing passenger fine but drivers side has just a smidgen of play gonna address that then get alignment after that check tire I notice a slight dip in the center of both tires
Old 02-10-18, 09:06 AM
PsykotiK
PsykotiK's Avatar
if you are running two different tires front and rear that are different speed ratings then its gonna feel loose
Old 02-10-18, 09:58 AM
Zerodrag
Zerodrag's Avatar
Semi-easy way to troubleshoot would be to just swap the rear wheels back to stock and see if the issue goes away. If it does, then it would do with the new set of rear wheels/tires.
From what I recall, an alignment normally isn't necessary when only swapping the wheels/tires.
Old 02-10-18, 10:37 AM
mrmj2u
mrmj2u's Avatar
You might want to get the rear wheels/tires balanced.
Issues with balance get worse with speed.
Old 02-10-18, 03:02 PM
Vitamin-SC
Vitamin-SC's Avatar
had rear balanced before putting them on
and as far a tires the front are all season and the rear are summer tires that are directional
Ohtsu fp7000 front new rear ohtsu fp8000 rear {used }were on rear rims when purchased
Old 02-10-18, 09:05 PM
shajbot
shajbot's Avatar
If it's determined that the new rims are causing the instability, you should get them some new(er) tires and better brand. Get them balanced again and get an alignment afterward.
Old 02-11-18, 11:51 AM
SpectraBlu
SpectraBlu's Avatar
I don't know how cold it is where you're at but, summer tires don't do so well under 45 degrees. I have summer tires on my GS and it feels like a completely different car when the temperature drops.
Old 02-11-18, 04:09 PM
Duck05
Duck05's Avatar
Check the hub size, too......
Old 02-12-18, 07:19 AM
RudysSC
RudysSC's Avatar
Received 1,207 Likes on 836 Posts
Same thing happened on my V8 car back in the day when it got sticky tires thrown on. I highly recommend a good 4-wheel alignment. Also, be sure to check your rear wheel bearings and all bushings in the rear before having the alignment completed. Tires are simply exacerbating a more predominant issue from the sounds of things.
Old 02-12-18, 10:03 AM
Vitamin-SC
Vitamin-SC's Avatar
is 350 wheels there hub centric with lexus lugs a well
Old 02-12-18, 11:27 PM
Brucelee28
Brucelee28's Avatar
Doesn't hurt to get the wheels rebalanced sometimes. I had a wheel balance once then had to get it rebalanced again. Sometimes the first guy doesn't do it right or missed a spot.
Quick Reply: Rear End very unstable after rim & tire change
