Fluctuating Revs/Rough Idle
91 Soarer 1UZFE
Revs stable when cold, gradually become more unstable as engine warms up. Fluctuation of 200-300 rpm when warm.
Codes 31, 24 - Air temp/volume.
Have done:
AFM replaced - no change
ECU checked - Recapped and tested
Ignition system checked - No shorts, good plugs, coils checked
Air/vacuum leaks checked - No leaks
Fuses pulled - Fuses fine
Fuel Pump bridged - no change
Suspect:
Because it's a temp related issue, either water temp, oil temp or oxy sensors. Value any input from others as to similar issues or fixes. Thanks.
Have done:
Suspect:
winter4w
39
02-07-18 11:04 PM
edge20
14
10-12-15 05:06 AM
