Muffler help and dash light help?
Couple questions sorry I'm a noob
have a muffler with 2.5 inlet I believe the sc stock inlet is 2.25 can I weld the muffler on or do I need the pipe adapter ?
do I really need exhaust hangers? Shop want to overcharge
should I use clamps instead ? Cops are *******s around here, I can switch back to stock just in case lol
when i turn my headlights on I can't see my dash or anything but when I turn the headlights off everything lights up again ? Might be a fuse? Can't see how fast I'm going at night lol
There is adjustment roller on the left side of your dash. Try to roll it fully to the right. Lights should light up, if not needs further investigation.
I've had a pipe shoot off my motorcycle that was connected with only a clamp...
I would definitely use exhaust hangers if you are concerned at all about noises in the cabin of your car.
Keeper of the light
Correct. Dash lights are always on, but when you turn the headlights on it redirects the voltage through a section of the dimmer module that drops the voltage. If you turn it all the way until it clicks full on it skips the dimmer section so if it still doesnt work you're going to need a volt meter and the diagrams i posted ten years ago you should be able to find in search to trace the circuit.
Lovecorond
RX - 1st Gen (1999-2003)
01-31-18 04:15 PM
