How to check ABS codes
Old 06-19-17, 11:34 AM
Bankswood
Bankswood's Avatar
Default How to check ABS codes
Anyone know the procedure for checking ABS codes in a 93 SC 400. The info I have is for a LS 400. It says to jump E1 and Tc and count the abs light flashes. All I get is a fast blinking CRUISE light.
I'm trying to determine if I have a bad whell speed senor and which whell it is on,
TIA
Old 06-20-17, 07:56 AM
t2d2
t2d2's Avatar
Tc & E1 is correct for ABS. Did you remove the little jumper pin from the engine diagnostics box? I don't know what the logic behind it is, but you have to remove that before doing the ABS test.
Old 06-21-17, 06:32 AM
salimshah
salimshah's Avatar
My problem may not be your problem, but I chased a ghost for 6 months on my RX. Service manual clearly stated make sure you have a fully charged battery. My trouble started with a battery going bad and the alternator charging system overworked and blew diodes. The burnt diodes were creating enough AC ripple to trigger ABS error for me. Once the rectifier bridge was replaced, no more ABS warning and I have spare brake modulator and controller board.
Salim
Old 06-22-17, 06:18 AM
Bankswood
Bankswood's Avatar
I have a friend that used to be a mechanic. He dug thru his old stuff and came up with an early model SnapOn OBD1 reader with the Toyota connector. Hooked it up and it showed a bad left rear speed sensor. So much easier than pin jumping.
I'm all about sharing so anyone in the Charlotte, NC area who would like to use it just let me know. I don't actually own it but I can check to see if he would allow me to mail it to anyone who needs it.
Old 10-05-18, 09:14 AM
Mjcotton
Mjcotton's Avatar
I am also in Charlotte with a 98 SC400 and ABS and flashing TRAC light. Is the OBDI scanner available? Mike
Smokie
RX - 1st Gen (1999-2003)
02-18-18 08:35 PM
aymaddemir
02-25-17 11:24 AM
franco305
Suspension and Brakes
03-12-15 04:05 AM
jayr1
07-07-14 05:00 AM
TedFury
08-19-13 07:22 AM
Quick Reply: How to check ABS codes
