NA-T Questions?? Ask the Guru
Silent, that is good news! at least it was something easy but that is a new one lol, the notches are super visible!!
Nuturf87, I don't understand what made you think you can run 1000cc on the tt ecu mod, especially ID 1000cc which are EV14 injectors and newer tech (so injector lag times are different than the original injectors for this ecu which are more like EV1).
even from the US ecu with 550cc, that is doubling it... which might have worked on E85 but on pump gas that is asking alot.
Also the usdm being a maf setup, its not going to scale as well as the jdm ecu from a piggyback, meaning its hard enough to get the USDM ecu to work on na-t with the stock 550cc injectors.
So in summary, I doubt it will start and run properly with ID1000 cc injectors, you might get it to start and idle to some degree but it won't be pretty when you tap the gas.
if its running for 5 seconds then it should do the same wihtout the starter fluid regardless of IGF there or not. for the 1zz coils you just connect all 6 IGF wires together to the stock IGF wire.
Get yourself some 550cc injectors of the old school variety that are top feed high impedance and work from there.
Or if you don't have to deal with emissions, just swap to a JDM ecu but still anything over 550cc or even 600cc on the jdm ecu will start to have problems.
on USDM ecu I wouldn't push more than stock 550's cause of the maf setup.
Basically get 550cc injectors and you can still do tweaks with the map ecu, but do note setting up the map ecu can be tricky, I have had no starts on the base maps lots of times without tweaking.
Also if you have an actual IAT in the loop, you should not put a resistor in place of the IAT on the maf connector, you do one or the other, not both. that could be part of your issue.
hope that sheds some light, good luck.
Did some research on the usdm tt ecu deal. So if install a set of 550cc ev1 high z injectors and install the stock tt MAF in a blow thru setup like post intake intercooler pipe would i be okay? Saw some videos and noticed that people who own supras that still run stock fuel/ecu have a single turbo setup running the stock tt ecu and run the stock injectors (550cc) and denso tt pump and have success with no piggyback controller and pretty large turbos 71mm etc can that be confirmed? I may be willing to remove me bosch injectors and find some 550cc ev 1 14mm tops due to the fact that I run a 14mm injector bung fuel rail. And give it another shot.
Any recommendations for a catch can setup? (Ali i know you said filters will be fine for pump gas stuff but i think id like to get one anyway)
Can i use any like 3 port can and run the two valve covers to it and the other lead to my turbo inlet?
Nuturf, not to sound harsh but I am feeling like you didn't read the beginning of the tt ecu mod thread. If you don't need emissions, which based on standalone talk I am guessing you don't.. you should get a jdm ecu.
With the JDM ecu you can use 550cc injectors and your map ecu piggyback, and run well with a single turbo up to 500ish hp.. this is about as far as I would recommend pushing the tt ecu mod (stock jdm injector size is 440cc).
The usdm ecu does not respond well to single turbo's cause its maf based, and it doesn't matter if you are using a piggyback with a map sensor, its still simulating the maf output to the ecu and wont work well.
All those guys who do it on supras with singles on usdm ecu's have issues, talk to one of them and see whats up. you will have more issues since your turbo is on the larger side.
so in short, 1000cc you are going to need a standalone. I would have never recommended the usdm ecu unless you need emissions as it is a pain and doesn't work well without a bunch of tweaking, still its iffy.
You could just puck up an aristo ecu from here and some 550cc injectors till you are ready for more power. 1000cc injectors wont do anything for you until you are running e85 or a standalone anyways.
Silent, you can run a can and at certain power levels you will need it, look for one with reasonable size ports, like two -10 AN in for the valvecovers... and for the line to the intake, don't do it and just run a large filter on top of the catch can.
make sure it's baffled and the hole for the filter is at least -10an also, and it should catch the oil without spraying.
Putting it back into the turbo intake on these cars at higher boost levels is going to make a mess of everything.
Check out some of Gerrbs latest builds in his build thread, he has some great setups.
This is his latest stealth na-t one, see the can in the top left, filter on top, and looks like 2 -10an size push loc hoses on the side but I can't say for sure just what it looks like =)
https://www.clublexus.com/forums/bui...l#post10661243
If you go back and look at some of his older builds you can see the lines and routing etc.. and various style cans he has used.
Also, If you ever get time to go through his build at almost 300 pages now... you will know pretty much everything you ever needed about 2jz's.
https://engineswapdepot.com/?p=50580
Alot going on the front of that thing, some kind of custom cam trigger along with what looks like a cam driven oil pump?!?
then throw in the na valve covers and the filler on the passenger side like a gte, although it looks like the waterneck is still on the passenger side just going to a AN line.
All the custom stuff is pretty neat, nice fab work but I don't get the roots supercharger other than the looks, I wouldn't even put one on my small block with the vortechs they have now.
Looks impressive though, but you will probably make more power on your setup lol.
I like how they tapped the valve covers like ours haha I might do my lines like this off to the passenger side into a can.
Methanol... makes sense actually. Yeah that is more or less how everyone is doing it these days on the catch can.
making me think of picking up another SC now to play with, there is a 97 that has some potential near me I want to look at but not sure I want to mess with obd2 here, will look at it and see what happens lol.
You should get another one!! haha
="5"%This is a thread for all my fellow Na-T people who have those random na-t questions they need answered like yesterday.
GTE peeps have too many threads already, this is Na-T related only.
I get tons of PM's for random Na-T questions and I find myself repeating lots of answers.
First, I am flattered yes thanks but after a while its a bunch of the same answers over and over again.
I will likely refer you to post here when you PM me if I think it will help others also.
If you want it to be anonymous I can post it without your screen name, but seriously no question is too easy when it comes to Na-T so just rip the band-aid off already.
Those of you who have asked me something via PM know I try and answer everyone back, so lets just get the common questions in one place on the forum and that will help out everyone (including my free time, thanks)
So ask it here and everyone can see the answers that I magically @%#@ out... seriously its magical.
Topics include Basic or advanced NA-T questions, FFIM, Fuel, ECU's, Tuning, theoretical physics (just checking if you are actually reading), catch can, charcoal canister, ACIS, whatever you can think of that remotely relates to Na-T.
="4"%And if you can stump the Na-T Guru... you will earn the title of Na-T Apprentice (or whatever you want really)
So things don't get crazy out of hand, I ask that you post your question with as much detail as possible, pics or videos are always good too if needed for clarity.
The quality of the answer will be equal to the quality of the question
I have a 2001 Gs300. It’s a VVTi and I want to go FFIM but I’m trying to keep my traction and cruise control. Now I’ve been looking for sometime and I can’t seem to get the right answers. What I’d like to know is, would a GTE throttle body work and if yes, which one (VVTi or Non VVTi) which year as well (if it matters) and besides fab work do you think there’d be any special electrical work to be done?
I’d also like to change my coils as well, would you recommend going lq9?
Hey, AliSc3
Why change the coils? vvti wasted spark coils will make good power. LQ9/LS coils will run hot from what i hear, if you're determined to swap to cop i'd go with TT coils.
