Adjusting idle on tps on Sc400
Old 02-16-16, 01:41 PM
LexiiBabe
LexiiBabe's Avatar
Default Adjusting idle on tps on Sc400
Soo sorry for asking. I've read the post on Lexls already but is still dumbfounded. Just having a hard time on how to actually adjust it. Any help.
Old 02-16-16, 06:19 PM
DrAtomica
DrAtomica's Avatar
The easiest method to adjust the TPS if you have a OBDII port is to plug in a scanning device and turn on the key to accessories, after that adjust it manually by turning the tps. You have to look at the device while you are turning it, once the TPS is adjusted to the percentage you want, just tighten the screw so it stays at that percentage.
Old 02-18-16, 03:53 PM
Bankswood
Bankswood's Avatar
any suggestions for those of us with OBD1?
Old 02-18-16, 08:10 PM
t2d2
t2d2's Avatar
Equal parts prayer and cursing.
Old 03-01-16, 11:28 AM
Devan
Devan's Avatar
I got lucky in that the previous owner marked the TPS positions So, all I had to do was slide it back to that point.
I have 2. I will never mess with them again.
I would rather dump the whole electronic TB and use a cable system instead.
Old 03-02-16, 11:01 PM
dogwisper
dogwisper's Avatar
I found this thread https://www.clublexus.com/forums/performance-and-maintenance/551125-the-definitive-guide-to-fixing-sc400-hesitation-issues.html
Scroll down to the section on adjusting the tps with the computer power cord. I found this the most effective,cheap and extremely creative way to adjust tps!
1UZStoked
08-14-13 02:34 PM
Redrek43
02-18-13 05:44 AM
vham62
SC- 1st Gen (1992-2000)
04-08-11 01:19 PM
vham62
03-30-11 05:44 PM
gnats
03-19-05 11:03 AM
Quick Reply: Adjusting idle on tps on Sc400
