over heating
Old 06-18-14, 10:42 AM
soarer1988
soarer1988's Avatar
Default over heating
My 1jz is over heating and keeps getting air in the cooling system i checked all the water lines and even change the head gasket and it still over heats what could it be o and when i let the d cell when in gear it starts to cool down help 1jz is stock with a 6266 turbo and a ported head
Old 06-18-14, 01:39 PM
soarer13oy
soarer13oy's Avatar
Are you losing any coolant? What kind of radiator/fan setup do you have?
Old 06-19-14, 10:56 AM
soarer1988
soarer1988's Avatar
I got to slim fans and yes i am i am getting air bubbles in my radiator i got a dual core aluminum radiator i got the car the way it is lol and its pissing me off as for its my dd for now
Old 06-20-14, 01:35 PM
soarer13oy
soarer13oy's Avatar
You might just have air bubbles which can cause your temp gauge to spike.
Old 06-20-14, 02:52 PM
Joey-E
Joey-E's Avatar
Try bleeding it so air bumbles are gone, is your rad cap good?
Old 06-21-14, 04:58 PM
soarer1988
soarer1988's Avatar
yes caps good and I let the air out of it it keeps getting more air I dont see a leak cap is the 1st thing I did its got a blitz cap
Old 06-21-14, 04:59 PM
soarer1988
soarer1988's Avatar
I have slim fans to should I put the oem fan back on
Old 06-21-14, 09:27 PM
Joey-E
Joey-E's Avatar
Yes, put OEM fan back on make sure new fans have the same or more fan speed if you want to go electric. I would stay oem tho. For the air bubbles try to bleed it for awhile, make sure heat is on high when you do this.
Old 06-22-14, 09:38 AM
soarer1988
soarer1988's Avatar
ok cool I will try 1 last time could it be the weep hole in the water pump sucking air in to my motor
Sin1UZFE
32
09-11-20 04:00 PM
Blakeg1991
06-27-13 05:12 AM
CrZxDrAgOn
31
08-21-12 11:31 AM
rykwebb
08-27-07 05:58 PM
jewelerz
01-02-03 02:29 AM
Quick Reply: over heating
