SC300 Vibrating heavily!
Old 05-14-14, 11:37 PM
MORPM
MORPM's Avatar
Unhappy SC300 Vibrating heavily!
Hello Lexus komrades, I currently own a 92' SC300, recently it started vibrating heavily when I would hit about 45mph+ and when letting off the pedal then going below 45 it drives normal no vibration... Yes I got the tires new, balanced and rotated them ✔ Some mechanics were also saying it was a driveshaft issue so I switched it out from another salvaged SC300 ✔ and I replaced the coupler flex on it as well (new) ✔ and finally I got a very good condition Rear subframe from a 98' and installed it and well it still vibrate but not as bad before... Any help I'd appreciate ! If Mods can put this in the correct category please I'm a Newbie to the forum.
Old 05-15-14, 12:34 AM
scENFORCER
scENFORCER's Avatar
Engine mount or tranny mount?
I hope this isint the first time you've posted here about this problem. Seems like with all the combined knowledge here on CL it would have been fixed a long time ago rather than going through all the expensive fixes you've tried.
Old 05-15-14, 10:17 AM
pur4orm
pur4orm's Avatar
Default Been there before.
Your tyranny is going. Hard to find good mechanics these days. Look at it this way....you have a car with age, no longer in production. Prepare to replace EVERYTHING. Sometimes it's costly but so is maintenance on a new car. Replace the tyranny n and you should be ok.
Old 05-15-14, 11:54 AM
1CleanSC
1CleanSC's Avatar
I sense a 5 speed swap in your future.
Old 05-15-14, 04:49 PM
Luxor
Luxor's Avatar
It's NOT a tranny issue.
Old 05-15-14, 08:56 PM
mikef
mikef's Avatar
just do a 2jzgte swap next, see if that helps lol
Old 05-15-14, 10:42 PM
Sylexus
Sylexus's Avatar
Mine did this as well, it suddenly stopped so I never got around to seeing the cause.
Old 05-15-14, 11:29 PM
perkins92
perkins92's Avatar
My 97 sc400 did this as well. It turned out to be both of the rubber engine mounts had ripped in half. Although, I also had my 93 sc300 to have a similar problem back in the day. The front driveshaft had somehow got unbalanced and caused vibrations at certain speeds, but if you have replaced yours with one that you know for a fact to be good then you shouldnt have any problem there.
Old 05-16-14, 02:08 AM
MORPM
MORPM's Avatar
I highly doubt it's tranny.. I've already been thru that as well lol usually I can feel the gears slippin' even if
Old 05-16-14, 02:13 AM
MORPM
MORPM's Avatar
It's like a very "fixed" vibration.. I feel like its with the bushings and mounts somewhere...
Old 05-16-14, 02:18 AM
MORPM
MORPM's Avatar
Exactly! Even the coupler flex. I remember doing an engine mount replacement as well 1 1/2year ago, Il check those again maybe the heat is eating away at the rubber.
Old 05-16-14, 02:24 AM
MORPM
MORPM's Avatar
Any spare parts bud lol
Old 05-16-14, 03:16 AM
AnonymousG
AnonymousG's Avatar
Did you do both mounts? Did you also do the transmission mount?
Old 05-20-14, 10:25 PM
MORPM
MORPM's Avatar
Alrighty so it seems that there's an issue with the differential bushings.. What's your advice guys should I go ahead and sell it or is there another possibility? I've already went thru 3 things to try knocking out the issue... it's like having a crazy psychotic gf lol
Old 05-20-14, 11:36 PM
scENFORCER
scENFORCER's Avatar
Diff bushings arent very expensive. Why make that cause you sell it?
I still think its you're tranny mount. When I replaced mine it got rid of a lot of vibrations, some of which were very similar symptoms to yours.
Quick Reply: SC300 Vibrating heavily!
