PCV Valve between valve cover and intake manifold
Super Moderator
^^^ if your pcv valve is bad or stuck open then oil is going into the intake and yes you will be burning oil.
Though there are a lot of other reasons like valve seals . When you first start it , does it produce a lot of smoke ? It can be a sign of valve seals. There are other possible reasons . But start from those two.
