what causes oil leaks in the front of the motor?
Old 10-18-13, 07:13 PM
durps
durps's Avatar
@tj, you got a driveway bro? If so might just head down there and we chill man.
And @sc4o0 which rubber gasket is good? Was just gonna go the toyota sealant, but a reg gasket sounds less messy lol.
Old 10-18-13, 08:44 PM
tjmhillz
tjmhillz's Avatar
Yea i do and garage lol. We can work on the cars if you want. I need to change my oil and install a few other things. I may not go to FCF tomorrow. Then we can cruise to Fusion after. I might just have a last might wrench meet at my place lol
Old 10-18-13, 10:56 PM
durps
durps's Avatar
Text me if you don't go bro. Was gonna text you right now but it's late lmao.
Old 02-28-14, 09:38 AM
SlowC400
SlowC400's Avatar
My Front main is leaking badly, has anyone replaced the Front main before? think you can give me some pointers???
Old 05-06-14, 05:45 PM
t2d2
t2d2's Avatar
Originally Posted by lexforlife
sc300 all use toyota black sealant only , no paper seal
Originally Posted by 99SC42
+ 1 same as the sc400
Is this correct? I need to change my oil pan gasket and was looking around for what type (brand, part #, etc.) is recommended. Mine is a '94 SC400, but it sounds like that doesn't matter based on the above quotes.
Old 05-06-14, 06:27 PM
bigwhite
bigwhite's Avatar
Im assuming with an upper and lower pan gasket that the engine needs to be pulled. Also most likely the easiest way to do the front seal. What isnt easy is all the time its going to take to get the engine in and out. Hope no exhaust bolts snap. I need to reseal my 93 so bad but am only qualified to pull the engine, I would have the resealing done by a pro.
Old 05-07-14, 09:44 AM
SpooledSC
SpooledSC's Avatar
Go to your local Toyota or Lexus dealer and ask for Part# 00295-00103. Should be around $14.xx plus tax.
Old 05-07-14, 06:09 PM
bigwhite
bigwhite's Avatar
So can you change the pan gaskets without pulling the engine?
Old 05-07-14, 06:17 PM
Vrank
Vrank's Avatar
Jesus ****ing Christ! There are zero pan gaskets! Its called FIPG! Toyota form in place gasket! Its a silicon type sealant! If you don't know what you're talking about then don't talk! Whoever posted that picture of that bootleg gasket set, that's horrible. Always use factory Toyota/Lexus seals or you're asking for trouble
Old 05-07-14, 06:41 PM
lexforlife
lexforlife's Avatar
mother of god ... ^^^^^^^^^ this , just follow the above
Old 05-08-14, 01:24 PM
SC4ME
SC4ME's Avatar
Originally Posted by GSXMike
Wrong, you don't know wtf you are talking about, sir. I have seen it happen over time and have changed several oil pan gaskets on iron block engines because of using the paper gasket.
Use the toyota bond gasket sealant ONLY. NO paper.
Same goes for mitsu bond, honda bond etc.
Want to test it? Dip a piece of paper in some oil, watch the paper absorb the oil.
Now squeeze out a drop of gasket sealant from the tube and let it dry. Once dry dip it in oil. Wipe the oil and with a razor blade slice open the center of the sealant, it will be clean on the inside. Likewise on the outside of your engine where it mates to the pan the sealant will remain dry because it's made to resist oil. That's why it's called a SEALant.
i didnt say anything about a paper gasket, ive never heard of such a thing. if you dont agree with something i say just ignore it, we are all posting opinions here.
Old 05-09-14, 03:32 PM
Vrank
Vrank's Avatar
Wrong again. We are posting facts. You are posting misinformation. Neither are opinions. If I hadn't have said anything to you, you wouldn't have deleted some posts. If you don't like people coming behind you and pointing out you don't know what you're talking about to prevent some people that might think that you do and waste time/money due to your lack of knowledge/experience, then YOU don't post. Simple.
Ryan300
RX - 1st Gen (1999-2003)
19
08-01-22 11:15 AM
markzystra
10-03-20 10:23 AM
mrjaydm
02-17-11 08:49 AM
TouringGS
Performance
02-08-04 12:46 PM
Quick Reply: what causes oil leaks in the front of the motor?
