Question Re Manual OBD Check
i have an intermittent problem with poor car performance that I would like to identify by
using a manual OBD check. By that I am referring to using a jumper wire across terminals TE1 and E1 at the diagnostic port under the hood ('93SC400). I would like to keep the jumper wire in place continuously until the problem shows up and then I can count the number of light blinks to determine the code number. My question is, can I leave the jumper wire in place without causing damage to the OBD system or causing problems with normal car performance. I am concerned that if the jumper is not in place when the problem pops up, I might miss the chance to get the readout because of losing the "on engine light" on restart...i.e., engine light disappears and car runs normal again. Hope this not too confusing. See Erratic Performance thread by SC93 for details of my problem. |
I don't see why it would hurt, but at the same time, I wouldn't leave it in place. I would assume the computer would store any codes and you can retrieve them once the check engine light comes on.
Can anyone else confirm or deny this? |
Obd1 data storage
Originally Posted by 1JZPWRD
(Post 8061483)
Can anyone else confirm or deny this? Thx for your reply. OBD 1 will not store problem codes for subsequent retrieval.... OBD2 will store for retrieval. I have OBD1. That is the basis for my question. I was having a problem which comes and goes. I was in one of those bad performance modes with engine light on When I drove up to my serviceman's garage, wouldn't you know, when I turned the ignition off and restarted the car, it started running normally. The engine light went off and he could not retrieve the the code number. The car may run normally for two weeks and then go into the poor performance mode. My problem is described under thread "Erratic Performance" submitted by SC93 yesterday. |
Originally Posted by SC93
(Post 8061549)
Thx for your reply.
OBD 1 will not store problem codes for subsequent retrieval.... OBD2 will store for retrieval. I have OBD1. OBD1 Codes 1 Normal Condition. 2 Air Flow Meter signal. 3 Ignition signal. 4 Engine Coolant Temperature Sensor signal. 5 Oxygen Sensor. 6 RPM signal (Crank Angle Pulse). 7 Throttle Position Sensor signal. 8 Intake Air Temperature Sensor signal. 9 Vehicle Speed Sensor signal. 10 Starter signal. 11 Switch signal. 11 ECU/ECM. 12 Knock Control Sensor signal. 12 RPM signal. 13 Knock Control CPU (ECM). 13 RPM signal. 14 Turbocharger Pressure. 15 Ignition signal. 21 Oxygen Sensor. 22 Engine Coolant Temperature Sensor signal. 23 Intake Air Temperature Sensor signal. 24 Intake Air Temperature Sensor signal. 25 Air-Fuel Ratio Lean. 26 Air-Fuel Ratio Rich. 27 Sub Oxygen Sensor signal. 28 No. 2 Oxygen Sensor signal. 31 Air Flow Meter signal (Vacuum Sensor signal). 32 Air Flow Meter signal. 34 Turbocharger Pressure signal. 35 Turbocharger Pressure Sensor signal. 35 HAC Sensor signal. 41 Throttle Position Sensor signal. 42 Vehicle Speed Sensor signal. 43 Starter signal. 51 Switch signal. 52 Knock Sensor signal. 53 Knock Sensor signal. 54 Inter-cooler ECM signal. 71 EGR System. 72 Fuel Cut Solenoid signal. 78 Fuel Pump Control signal. 81 TCM Communication. 83 TCM Communication. 84 TCM Communication. 85 TCM Communication. Good luck! |
(Post 8061549)
Thx for your reply.
OBD 1 will not store problem codes for subsequent retrieval.... OBD2 will store for retrieval. I have OBD1. That is the basis for my question. I was having a problem which comes and goes. I was in one of those bad performance modes with engine light on When I drove up to my serviceman's garage, wouldn't you know, when I turned the ignition off and restarted the car, it started running normally. The engine light went off and he could not retrieve the the code number. The car may run normally for two weeks and then go into the poor performance mode. My problem is described under thread "Erratic Performance" submitted by SC93 yesterday. The solution is easy though, next time it happens, do not turn the car off. you can place the jumper in the diagnostic port with the car running. The cel will not have a chance to go off this way and you will be able to pull the code. If you are driving around with the jumper in all the time, you may not even get any new codes I am not sure anyone has tried that and I wouldn't because it will severly reduce your timing and not run as efficient at all. |
| All times are GMT -7. The time now is 06:15 PM. |
