Can I access the engine coolant temp sensor without removing pass side sp plug cover?
1 Attachment(s)
Hi,
Can I access the engine coolant temp sensor without removing intake, pass side spark plug cover etc. ? (1UZFE) I'm a just getting into car DIY so i am trying to avoid pulling too much crucial stuff off while parked on the street in NYC. It HAS to start again by morning or it gets towed. It looks like i just need to get the spark plug wire channel up and forward and possibly unscrew the front coil pack but I don't have good light and cant see what's holding it in. Can i get a small socket under there to get it out possibly? Do I have access to it if i just remove the two things pictured below? If not, is there a really clear DIY that shows how everything comes off of the passenger side of the motor that blocks access to the plugs etc.. I'm working up the nerve to do my upcoming tune-up myself because I was looking at half of the job already when I got all the covers off looking for the temp sensor..... why not huh? 95' Sc400 117K Thanks, SG |
Moved to proper forum, along with others recently, please make sure you use the engine forum. :)
| All times are GMT -7. The time now is 11:11 PM. |
